Old 02-22-2021, 04:52 PM
Kupde Kupde is offline
Default EGT Fluctuation
Just changed out the fuel restrictions on cyl#3 and #4 on my RV-10 from an 0.028 to a 0.027. Test flight shows a very brief EGT drop(3 to 5 seconds) while going through the leaning operation on cylinder #3 only. Cylinder #3 drops about 200 degrees below the others(1200F vs 1400F) for the 3 to 5 seconds and then recovers with no further fluctuations. This repeats anytime going back through a leaning operation at different altitudes and engine settings. Never seen this before- anyone have any thoughts?
Kevin
RV-10
Old 02-22-2021, 05:25 PM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Very interested in the replies you get on this. I'll be balancing my injectors soon as I progress through phase 1.
My EGT on one cyl scrolled quickly downward and back up again shortly before the Dynon-supplied probe in question went T.U. for good, and had to be replaced at about 5 hours TT.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD - Phase 1 flying
Donation constant, K, = 1/woke censorship; not looking good this year.
Old 02-22-2021, 10:11 PM
Lt Dan Lt Dan is offline
What did the CHT do?
08 RV-4
09 RV-8
Old 02-23-2021, 05:34 AM
Raymo's Avatar
Raymo Raymo is offline
Sounds like #3 is running too lean. Can you upload the data to Savvy and share a link?
Ray
Old 02-23-2021, 07:16 AM
bjdecker's Avatar
bjdecker bjdecker is online now
Kevin
RV-10
I would be very suspicious of that EGT probe/wiring. I had a similar pre-failure signature on one of my ALCOR EGT probes very early on (~50 hours).
Swap the probe, see if the signature follows the probe -- if so, replace the probe.
Usually, issues with fuel injectors resolve themselves VERY quickly -- like a stumble that the EIS doesn't even see, or they don't resolve at all -- total blockage.
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 02-23-2021, 07:37 AM
lr172 lr172 is offline
+1
Sounds more like an indication problem than a fuel delivery problem. Pretty hard to have a fuel issue that can cause an EGT to drop then regain 200* in 3 seconds.
Larry
https://apps.savvyaviation.com/fligh...3-b3c28bb00ca0
Not sure if you can get to the data with the link above? Also, no change in CHT and I'll do as suggested with the EGT probe.
Kevin
RV-10
Old 02-23-2021, 08:04 AM
Raymo's Avatar
Kevin
RV-10
Thanks for the link. Definitely a probe connection issue, as mentioned above. GAMI spread is pretty good with #2 trending leaner.
Time: 00:14:28-00:14:54
EGT2 peaked at 12.2
EGT3 peaked at 12
EGT1 peaked at 11.8
EGT4 peaked at 11.8
EGT5 peaked at 11.8
EGT6 peaked at 11.8
GAMI spread is 0.4
Ray
Old 02-23-2021, 08:56 AM
bjdecker's Avatar
Default I love data...
You can definitely see something going on there --
EGT on #3 drops out frequently, 9:08, 16:20, 19:29, and so on, regardless of fuel flow settings.
Brian Decker
1986 Mooney 205SE
1980 Mooney 231
Old 02-23-2021, 02:51 PM
bjdecker's Avatar
Default Another oddity...
Keep an eye on the #2 CHT.
Note 11:41 to 14:32 and 21:08 to 26:41 -- #2 CHT is NOT following the normal distribution or rate of change.
This tells me the #2 Cylinder is burning too hot / too fast as the fuel flow increases (richer:faster, leaner:slower), change to a smaller orifice (e.g. .027" from .028") and see if that curve flattens out.
Brian Decker
1986 Mooney 205SE
1980 Mooney 231
Last edited by bjdecker : 02-23-2021 at 02:57 PM. Reason: updated recommendations.
