I got my Andair fuel valve mounted today and spent a little time looking at some future steps like mounting the fuel pump. I plan on mounting the pump on the left side forward bay up by the rudder pedals. Since I have a QB fuselage I don't have access to the false floor to install plate nuts. I was thinking about installing rivnuts to bolt the pump body down but wondered if there was a more elegant solution.
How did you do it?
General question. Talk to me about fuel flow transducers.
Who's transducer did you use? Where did you mount it? If you had to do it all over again what would you do differently?
How did you do it?
