  #11
Old 08-23-2021, 12:20 AM
NinerBikes NinerBikes is offline
Originally Posted by CaptBob View Post
Great input WRT the RV-12 rib and spar aluminum thickness, NinerBikes! That's the kind of specific insight I'm looking for.
I believe I read on the website that the RV-12 is an aerobatic airplane -- I would assume it's pretty easy to exceed Vne on the backside of a loop if you aren't careful about holding in the G-loading, correct?
Bob Jackson
N2XF
PS I'm actually a lot more of an Electrical than an Aero engineer, and although I do have a MS in Aeronautical Systems (courtesy of the Navy) my aerodynamics theory is not that strong!
RV-6 7 and 8 are +6 G, -3G and rated mild aerobatic, not like an Extra 300. RV-9 and RV-12 models are rated "Utility"... No spin planes.
Spend some more time on Van's website to gain more familiarity with the various models and their capabilities, performance, and specifications.
Donated
RV-12, KWHP based
"Time to Spare, go by Air."
Old 08-23-2021, 08:11 AM
Amadeus Amadeus is offline
Default RV-9A
The RV-12 was designed to meet the needs of a certain niche. Look at the RV-9A. Build costs are very similar so why try to make impossible changes to the -12 when the -9A has everything you are wanting to achieve?
Purchased N112DR E-LSA flying with 28.2 hours - Thank you David (CraftingN112DR) for putting your skills, knowledge and attention to detail in this RV-12iS!
Dropped at paint shop this morning (July 15, 2021)
Picked up from paint shop (August 14, 2021)
Donated
Old 08-23-2021, 01:27 PM
hamblin10's Avatar
hamblin10 hamblin10 is offline
As a structural aerospace engineer I can tell you the Vne is more based on flutter response than actual airloads. If you exceed Vne and experience flutter your aircraft will come apart as if a bomb went off inside. You will not have time to even start throttling back. I recommend NOT placing a larger engine on. This is not a street rod.
Eric Hamblin
Private Pilot/A&P/Aerospace Engineer
RV-12iS in progress. N993EZ
Build 121398
Empennage kit ordered 9/30/21
Wing kit ordered 11/8/21
Owasso Oklahoma
https://eaabuilderslog.org/?s=MYRV12
Old 08-23-2021, 01:31 PM
rvbuilder2002's Avatar
Utility category is 4.4 G's
That is what the RV-9 was designed to meet.
For LSA it is 4.0 G's
That is what the RV-12 was designed to meet.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 08-23-2021, 02:20 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
I would watch this... https://youtu.be/_OuNJ14RyaQ
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 750
Old 08-23-2021, 03:37 PM
Bernardo's Avatar
Bernardo Bernardo is offline
... I see no reason why standard E-AB flight testing can’t be down with incremental flutter testing to extend the Vne well above even the cruising (and ‘downhill’) airspeeds achievable as configured with the bigger 915iS engine...
I see a reason: Flutter.
Watch this video:
https://www.youtube.com/watch?v=egDWh7jnNic#t=95
Do you really want to be the pilot of an airplane that is going through this?
RV-6, 6A, 7A, 9A, & 12 pilot/co-owner. Aeronautical engineer, researcher, lecturer, author. Stanford, Boeing, etc.
Worked on wind-tunnel research, on design & modeling of rocket & jet engines, control systems for UAVs & spacecraft, jetliner maintenance planning, lab tests & computer modeling of innovative aero structures, future airplane design… But I have always wanted to work for a small company, on airplanes optimized for fun rather than profit, and no airplane is more fun than an RV!
Old 08-23-2021, 05:59 PM
JosephineJ79 JosephineJ79 is offline
Well of course airfoils are supposed to flop up and down. Haven't you ever watched birds fly?
