Old 08-16-2021, 06:48 PM
keith6261 keith6261 is offline
Default Showplanes Cowling with Hartzell Composite Prop and Spinner
Looking for help with Hartzell model numbers for composite prop and spinner that will fit the Showplanes cowing with a Lycoming IO360 180HP. Thanks
Old 08-17-2021, 12:41 AM
Bootscooter's Avatar
Bootscooter Bootscooter is offline
I have this combo I am just building now
From Hartzell: C-3533 Spinner Assembly to meet the Showplanes cowl dimensions . This Spinner Assembly is nearly 14.9” in diameter and is non polished. There is also the chrome polished version sorry not sure of that part number, contact Hartzell or Vans if required
It will require the addition of a A-2476-48 spinner mounting kit.
The hartzell composite prop I bought through Vans is G2YR/N7605W-2X it has the extended hub that is required with the Showplanes cowl.
Rgs Chad
Chad Boot
RV8 Showplanes Fastback in progress
RV14 140331 VH-VNX. Flying/Sold Winner Concourse D'Elegance SAAA Narromine 2018
RV10 Standard Fuselage Complete
RV10 Empennage complete
RV-7 Flying VH-VNZ
Tech Councillor - Sports Aircraft Assn of Australia
2021 Dues Paid
Old 08-17-2021, 03:56 AM
Northernliving Northernliving is offline
I just installed this prop/spinner on my engine/prop upgrade. I used the part numbers from the Vans site (G2YR/N7605W-2X for the prop and D-4798P for the spinner(polished)) and am using the standard Vans cowl. I found the adjustments on the spinner to set the gap on the cowl very simple and accommodating. This prop comes with the extended hub required two avoided any interference with the cowl.
If you need me to measure anything, send me a PM.
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
New Superior IO-360-B1AC2 w/Hartzell Composite CS
RV8 - #83313 - Under Construction (sort of!)
Old 08-17-2021, 06:43 AM
Thanks so much guys i'll be in touch.
Old 04-25-2022, 10:51 AM
JDA_BTR JDA_BTR is offline
I'm working through the same configuration. How much is the hub extension? Is it 2.5" or less? Have you finished fitting the showplanes cowl with the G2YR/N7605W-2X prop and what problems did you run into?
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 05-20-2022, 06:04 PM
Cwood2000's Avatar
Cwood2000 Cwood2000 is offline
Waiting for a response as I am in the same boat. BTW, I'll be flying my RV14 to CS next month to visit my daughter, any suggestions about where to fly in and out of and possible hangar?
Aka YellaDawg
RV4 N58490 (Non Build)
RV4 N621H (Non Build)
RV14 N951CW First Flight 10.15.2019
RV14A N957VW First Flight 11.8.2021 (Sold)
RV8 N880CW Under Construction
2022 Dues Paid
Old 05-26-2022, 03:06 PM
TParker TParker is offline
The G hub extension, which is one inch longer than the stock C hub, with the N7605() blades was configured to be used in conjunction with the D-4798(P) spinner when installed with the stock RV-8 cowling due to the cowling's unique shape in order to prevent cowling interference issues with the wide blades at high pitch. Effectively, the G hub moves the blades forward and then the D-4798(P) negates some of that movement such that the cowling to blade spacing is increased.
The available integral extension needed to mimic a 2.5" extension over stock as specified by Showplanes would be an M extension, i.e. HC-M2YR-1()X/(), which is nominally 2.563" longer than stock.
The C-3533(-1)(P) spinner provides similar spacing between the blades and the aft edge of the spinner as the G hub/D-4798(P) combo at the increased diameter for the Showplanes cowling. I am unsure as to the specific geometry of the Showplanes cowling, and whether this clearance would be adequate.
Trevor Parker, Engineer, Hartzell Propeller
Opinions, information, and comments are my own except as noted. Guidance provided here may or may not be applicable to your specific installation.
