Keep VAF
Going
08-28-2013, 10:47 AM
Oil Hatch bulging in flight
I made the first flight of my RV-8 the other day and noted that the hinge side of the oil door bulges out slightly due to air pressure. I have used the hidden hinge and the standard vans latch fittings without the wing nut ears. Is there a good way to stiffen the door? I have thought about adding a small piece of channel to the underside of the door or possibly installing a couple more of the push and turn fasteners at the hinge corners.
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2022
08-28-2013, 11:22 AM
I elected to live with it.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
08-28-2013, 11:43 AM
Here's how I did mine. Seemed to keep the shape in line just fine.
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2021 Paid
08-28-2013, 01:08 PM
Here is how I did mine
Another approach is fiberglass over foam core. Not flying yet but seems very stiff.
John Harrell
RV-7A Tip-up, Aero Sport Power IO-360, Dual PMags, AFP FI, Catto 3-blade, Dual Dynon Skyviews
Flying since August 2014
Mission Viejo, CA
http://www.johnsrv7a.wordpress.com
08-28-2013, 02:21 PM
I think we're all saying the same thing - it needs beefing up - I wonder if this might not be best made out of stiff aluminium sheet?
Bob Ellis
www.rv-8.co.uk
G-JBTR Having a ball flying this wonderful machine
Donation July 2016
08-28-2013, 02:30 PM
I replaced mine with .050 alum.. Never bulged or popped open since. It was time consuming getting the compound curve correct.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
08-28-2013, 02:47 PM
I have a hidden latch which is based on a simple piece of hinge (left over from seat rail) and operated by a pull/push piece of wire from the air inlet. It keeps it from going anywhere and a cleaner look (my opinion)
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - Out of Paint shop & flying
Dues paid
08-28-2013, 02:59 PM
I carefully cut out the oil door recess and saved the piece of pink fiberglass. I bonded it with epoxy under the oil door and it is very stiff now.
08-29-2013, 07:44 AM
Super Moderator
What Bruce said. It may be too late now, but for anyone still building, use the piece of fiberglass you cut out from the cowl and then fiberglass that to the underside of the door. Works great as a stiffener.
Chris
Chris Pratt (2022 VAF DUES PAID)
RV-8 Flying, 900+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, TX)
08-29-2013, 09:20 AM
Part numbers for hidden hinge and latch mechanism?
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
Thread Tools |
Display Modes |
