Old 05-19-2022, 02:46 PM
jcl777 jcl777 is offline
Default Missing Generator Ground Wires?
RV-12iS build w Garmin avionics. Page 42MiS/U-14 shows generator A ground K6282, and generator B ground K6283. These donít exist anywhere on the wiring harness or in our inventory. Any ideas?
John Leon
Kingwood, TX
RV-12iS, N221TF, #121130
Old 05-19-2022, 08:24 PM
madmax4499 madmax4499 is offline
on the dynon system they both come off the back up battery switch.
Old 05-19-2022, 08:26 PM
VFR or IFR pkg?
Old 05-19-2022, 08:51 PM
rcarsey's Avatar
rcarsey rcarsey is offline
K6282 is a wire that goes from the Generator A grounding block to the EMS Battery Backup switch in the center console. I can't remember if it was zip tied to the harness.. or loose in a brown bag.. but I did have a little trouble finding a couple wires connecting to that fusebox.. and I think those were it.
K6283 is similar, but goes to the Generator B grounding block.
Rob Carsey, North Brunswick NJ
RV-12iS (N713) / Completed 12/2020
ASEL, Glider, AGI/IGI, LSRM-I, FCC GROL
Old 05-20-2022, 06:05 AM
Originally Posted by madmax4499 View Post
VFR or IFR pkg?
VFR, autopilot, single G3x Touch
John Leon
Kingwood, TX
Old 05-20-2022, 01:41 PM
N8DAV8R N8DAV8R is offline
I just completed this part, mine were in the harness. I think I recall that I was puzzled to find them for a while myself but they were there. I think I was either looking for black wires (like the grounds attached just before), or I had inadvertently bunched them in the with the other wires that attach to the bottom of the fuse box.
Good luck. I would guess that they are there, hiding.
Nate - Salida, Ca
RV-12is - Airframe kits complete. Avionics installed. Finishing firewall forward.
