Old 03-06-2013, 10:30 PM
Janekom's Avatar
Janekom Janekom is offline
Default LED Cowl lights
We all know that the wing tip lights means nothing while taxiing at night. Someone else recently posted his solution and at the time I have mentioned that I am also working on something. Well it is done and I am happy with the outcome. At this stage I have two type MR16 (38 degrees) in there that gives a quite a big spread, but I can also change it and try narrower angle lamps.
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-IBA - Flying and getting lots of TLC
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)(Sold again) Flying
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2022 WITH A SMILE
Old 03-07-2013, 01:34 AM
digidocs's Avatar
digidocs digidocs is offline
That looks great. More pictures and details please!
David
Old 03-07-2013, 06:21 AM
Janekom's Avatar
The picture below sure pretty much all the parts I had to make.
The next two shows the wiring - it is taped in with foil tape. I use the same as heat shields in the cowls.
And then a close up. Picked up one problem in that the RH one is very close to the alternator. If I do it again, I will lower it by about 1 inch.
Jan Hanekom
South Africa
Old 03-07-2013, 06:58 AM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default Nice
Looks good.
I am lookin for a solution like that. Just didnt feel good cutting holes in the wings. Keep us updated. Will be very interested how it handles, heat,vibration and amount of light.
Very nice work.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 7 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 03-07-2013, 08:02 AM
Aerosport1's Avatar
Aerosport1 Aerosport1 is offline
Here is another solution available for the RV-10 cowl. Available from Aerosport
Products. Easy to install and designed to be installed in painted aircraft.
http://aerosportproducts.com
Geoff Combs
RV-10 N829GW 865hrs
1940 Piper J3 Cub
Rans S21
Old 03-07-2013, 10:53 AM
Janekom's Avatar
The One from Aerosport looks really nice as well.
BUT - I have lost a bit of sleep thinking about those holes that I have to cut.
I I had to cut this huge hole I would even have lost more sleep
I have also thought about symmetry and me and Rudi have discussed it at length. I have also given the prop blanking it somewhat when at idle. Maybe I am wrong but with two small holes the prop only blanks one at a time. In the end the two small hole won
I guess the end result will be almost the same.
Jan Hanekom
South Africa
Old 03-08-2013, 10:10 AM
yooper's Avatar
yooper yooper is offline
Default Lights
I saw a Kitfox years ago with a light nicely faired into the front of both wheel pants (taildragger). I always thought that was a neat look, and our wheelpants are plenty big, especially on the -10.
Old 03-09-2013, 07:12 AM
Janekom's Avatar
I have also considered the wheel pants at some stage, but making a lens might be a problem.
Jan Hanekom
South Africa
Old 03-09-2013, 01:36 PM
iowaflyer iowaflyer is offline
Where can I find those MR-16 LED bulbs? What are the specs on them?
Old 03-11-2013, 12:10 AM
Janekom's Avatar
Mine is 5W with a 38 degree angle.
Telling you where I found it will not help you - I am in South Africa.
I guess your closest home depot will have similar.
Jan Hanekom
South Africa
