Old 03-02-2013, 08:01 PM
Bwing96 Bwing96 is offline
Default Sky Radar
For those that have the iFly and Sky Radar, where did you mount them?
Soon I will have my new to me RV-6/slider and think finding a place for the iFly 720 won't be much of a problem but my sky radar is the older S-2 model which looks just like the D-2 but has only 1 long antennae.
Can you mount the skyradar behind the seat and it still work as good as it does laying on the glare shield?
Old 03-02-2013, 08:27 PM
tturner tturner is offline
I mounted my Skyradar receiver on the right side wall just behind the right seat. Works fine. RV-6 slider.
Tommy Turner
Fayetteville GA
RV-4 sold
RV-6 sold
RV-8 Flying
RV-14A building
Old 03-03-2013, 01:26 AM
OneCharlieKilo's Avatar
OneCharlieKilo OneCharlieKilo is offline
I don't have the Sky Radar but for the iFly mounting, I initially used RAM mount on side rail that I had previously used for holding my iPhone:
then I removed the Lowrance 2000C GPS I had installed in the panel and mounted the iFly in it's place (before the iFly upgrade that allowed portrait mode display):
And current configuration:
Complete description of panel change from Lowrance to iFly is at:
http://rv6aproject.ckhand.com/panelA...l/panelPg7.htm
Chris
RV-6A, N731CK, 300+ hrs
Poulsbo, WA
Old 03-25-2013, 07:21 PM
Carlos151's Avatar
Carlos151 Carlos151 is online now
Not familiar with the RV-6 so when you say behind the right seat, is that behind the bulkhead? I'm considering the Skyradar unit and that would be great if I could mount it behind the rear seat in my -8, and still get a good signal.
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
TN26
Build Log
Old 03-25-2013, 09:40 PM
Default Skyradar
I think what he is saying is the skradar is mounted to the side wall of the luggage compartment which is behind the seats. I plan on mounting mine in the luggage compartment as soon as I get my plane.
Old 03-26-2013, 10:18 AM
walkman's Avatar
walkman walkman is offline
Default Sharing the output?
Soon, very soon I hope, I will have my -6 back in the air. I will have a new HXr and an iFly 720. Is it possible to share the output of the sky radar between the two units?
Btw if you ever go with the Airgizmo panel mount for the iFly you will need a 90 degree USB adapter if you want to use the USB port.
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 03-28-2013, 04:35 PM
Flybuddy2's Avatar
Flybuddy2 Flybuddy2 is offline
I put mine on an external antenna and hardwired the power. If you do that you can remotely mount it pretty much anywhere.
Old 03-28-2013, 04:51 PM
RV8iator's Avatar
RV8iator RV8iator is offline
You use the USB output from the Skyradar to the HXr and Wifi from the Skyradar to the iFly 720. You also can use the Skyradar WiFI to run the WX and traffis on your iPad If you want it.
Jerry "Widget" Morris
RV 8, N8JL, 3,200+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2007 - 2022
I just wish I could afford to live the way I do
Old 03-28-2013, 07:47 PM
dtw_rv6 dtw_rv6 is offline
Default skyradar location
no photo, but I velcro'd my Skyradar to the top of my battery box (-6 slider, battery just aft of the firewall). I installed remote antennas, but was able to use the local mounted antennas to get ads-b signal from inside my hangar. Not sure if I really needed the remotes.
Don
Old 03-29-2013, 04:50 AM
dmaib's Avatar
dmaib dmaib is offline
If you are using remote xpdr antennas do you need two of them? One for 1090 and one for 978? (D-2)
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/1/2022
"In '69 I was 21, and I called the road my own"
Jackson Browne
