Auburntsts
I've mounted my PlanePower alternator and I'm ready to safety wire the 2 tension arm bolts but I'm not sure what's the acceptable technique. The bolts are relatively far apart (5 or so inches) so I'm unsure if it's OK to safety them together even with that much space between them or to safety them separately to the engine or the tension arm (not sure if that's OK either as there's really no dedicated place to do that near either of the bolts). 43-13 is of no help -- what have others done?
