Old 11-19-2012, 09:31 AM
Dayton Murdock's Avatar
Dayton Murdock Dayton Murdock is offline
Default AFS 4500 Install
Hi All
I just thought I would give you a shot of my progress with the install of my AFS 4500. All of the engine and fuel tank sensors are finished; I remove the left tank to run the wires for the OAT. What’s left to do is mount the Ahars, connect the radios to the efis, and then button everything up after all the calibration is done
[IMG][/IMG]
Dayton Murdock
VAF#408 RV4 N359DM O360 C/S, Dual P_Mags, AFS Efis, Trutrak A/P, Leather, Electric trim and flaps, Led lights, Freeflight ADSB and it is painted Red, Flying 1105 hrs 11/28/20
Builder Log
Old 11-19-2012, 09:37 AM
RV6airplanePilot's Avatar
RV6airplanePilot RV6airplanePilot is offline
Default Looks great!
Glad to hear it is going well,
Dale
ATP, dreamer and maintainer; but not a builder
RV6a N18XP 960TT (builder: Jerry Cochran)
RV6a flight experience 2100 hrs
Superior IO-360 2007
Hartzell Blended Airfoil Prop
Dual LS EI, Dual Battery
GRT HX efis & RAIM GPS, 2 axis GRT autopilot
G696, GDL39 WX, Traffic
Dynon D10
Gear Leg Stiffeners from Woodmanrog
Old 11-19-2012, 08:48 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Keep on truckin' Dayton - you'll be there soon!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-21-2012, 04:12 PM
penguin penguin is offline
Sure is easier on a 4 than a 6! It is all worthwhile!
Pete
Old 11-22-2012, 04:46 PM
Default AFS 4500 and SL40 to GPS 396
I have a question
I need to connect the EFIS and the SL40 to my GPS 396 .The blue wire RxD data output from the 396, Should I just splice the to together? or can I only have one connected? efis or sl40
Dayton Murdock
Builder Log
Old 11-22-2012, 06:17 PM
Brantel's Avatar
Brantel Brantel is offline
You can splice it. One transmitter can drive a couple receive devices just fine and some even more. Technically however RS232 is a point to point spec. but it will work most times within reason. Don't forget to set your 396 to NMEA and VHF out to get it to send frequencies to the SL40.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 11-24-2012, 07:59 PM
Default Powered up today
Well I added power to the EFIS today and all the smoke stayed in the wires.
I can't quite figure out how to set the parameters yet. I need to configure com 1 to receive the GPS signal
Dayton Murdock
Builder Log
Old 12-23-2012, 07:49 AM
Unhappy Fuel System Trouble
Hi Everyone
I have all the sensors in my efis install functioning correctly except for the capacitance fuel level system. The previous system was manufacture by Electronic International and it performed flawlessly for 5 years. I thought a new system of the same nature would be a plug and play. That has not my experience.
I need some help to correct this.
Thanks in advance
Dayton Murdock
Builder Log
Old 12-23-2012, 08:00 AM
rv8guy's Avatar
rv8guy rv8guy is offline
Dayton
I can't help with that but I know you'll figure it out
Have a great Holiday You and Ian
Marshall Jacobson
"Miss Sue"
RV-8 80749 slow build taildragger
7.5 year build first flight Dec 2005
SOLD at 540 hours and 10 years of FUN
N68AK
Watkinsville, Georgia
Old 12-23-2012, 09:19 AM
rleffler's Avatar
rleffler rleffler is offline
I can't help you with your issue, but you will get a quicker response if you post to the AFS Support forum.
http://www.advanced-flight-systems.com/Forum2/forum.php
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
