Old 04-24-2012, 11:32 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Tip: An "alternate" Alternate Air Door
1 of 4
Depending on your point of view, this may be a solution looking for a problem. However, in the spirit of sharing ideas and techniques, I submit an "alternate", Alternate Air Door for your consideration .
I'm using an IO-375 in my RV-7 with Precision Airmotive injection and horizontal induction. This configuration has the air filter in the left cowl inlet and uses the infamous fiberglass "snorkel" to connect down to the fuel servo. The photo below is the alternate air door that Van's supplies for this application.
It mounts to the outboard side of the snorkel. Now I'm sure that, properly installed, this setup is perfectly adequate for the purpose - hopefully it should never have to be used. However, there has been much discussion in the forums about this design (and other alternate air doors for other configurations) failing over time just due to the vibration environment they live in. I was concerned about this but the thing that bothered me the most about this design though, is the one-way nature of it. I just don't like the thought that there is a control in the cockpit that if operated (even inadvertantly), required the cowling to be removed to reset it. I thought I'd take a shot at an improved design.
My critera was:
- must be able to open AND close using the cockpit control.
- maximum use of composite materials to get away from aluminum fatigue issues.
- no hardware exposed to interior of snorkel (to prevent ingestion hazard in case of failure).
- fit in same spot as Van's door.
What I came up with was this:
The whole assembly fits within the "sideview" of the snorkel. The pivot bolt does overhang a bit below the area where the snorkel tapers back inboard, but this is by design. There is plenty of clearance to the cowl everywhere. (Note: this might be a bit tighter on an RV-8 cowl - don't know though). The final "V" shaped opening has the same area as the Van's design (~4.4 sq. in.). Key to the design though is that the top of the pivoting door is carried in a "slot" formed into the back plate. This doesn't show on the cardboard template, but stay tuned.
to be continued in part 2 of 4 . . . . . .
Dan Langhout
2021 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
837 hours and counting . . . .
28 Pilots N Paws Flights
Now based at Moontown (3M5)
Old 04-25-2012, 12:06 AM
Default "alternate" Alternate Air Door part 2 of 4
Because of the design using a slot to carry the top part of the door, it was very important that the backplate and slot be very stiff (no warping allowed). Carbon fiber is much stiffer than fiberglass (and I had plenty laying around) so this was the material of choice. This fit in with the desire to maximize the use of composite materials.
Started off cutting a 6-1/2+ inch diameter blank out of some .071" aluminum I had left over from making my instrument panel. Chucked it up on the drill press afterwards and trued it up using files, etc. to 6-1/2". (yeah I know, I should get a lathe). Careful, no scratches.
After 3 coats of Johnson's paste wax on the disc, I laid up this nasty looking mess on a flat board. 8 plies of plain weave under the disc, 6 plies around the top edge, and 7 plies overlaping the top edge by about an inch.
There's more to the layup than meets the eye. To ensure that I pulled a really smooth surface off the "bottom" of the disc, I laid the first 8 layers OVER the disc (i.e. I didn't put down 8 layers and then lay the disc on it). Doing the layup over the disc enabled me to make sure there were no air pockets, etc to mar the finish. After the last layer, I covered it with peel ply and then put another flat board on top of that and flipped the whole thing over. After removing the first board, I did the rest of the layups.
After letting this mess cure out, I match drilled the carbon through the center hole in the disc and after a little persuasion with a large punch and hammer, yielded this:
After a little cleanup, edge trimming, and sanding to flatten the top overhang surface, I stuck the disc back in the slot to act as a shield so I could trim the slot overhang down to about 5/16" wide.
to be continued in part 3 of 4 . . . . . .
Dan Langhout
Old 04-25-2012, 12:38 AM
Default "alternate" Alternate Air Door part 3 of 4
So here's the backplate after being cut out from the carbon blank. That's a temporary .063" aluminum door in the photo just to test everything out. Note that there is an adel clamp attached to the edge as well. More on this in a bit.
Not focused as well as I'd like, but you can see the formed-in slot that the top of the door rides in. Recall that the aluminum disc blank was made from .071". This was important to provide a bit of clearance for the .063" thick door (obviously about .008")
The door pivoting action is very smooth with very little play.
Earlier I pointed out the adel clamp on the edge of the backplate. It turns out there is just enough room, due to the curved corner on the snorkel to sneak a nutplate behind the backplate. Just a bit of the snorkel has to be ground to give clearance for the #8 screw to protrude into. You can see the fit in the following photo. This will ultimately be buried under a flox filet. This mount provides a much better place to carry the end of the bowden cable housing than hanging it off #2 cylinder oil return line nut (the Van's door design).
In this photo, you can see how the head of the pivot bolt just tucks up to the curved surface of the snorkel without actually having to cut a hole through the surface. The bolt head will utimately be embedded in epoxy and a flox fillet, so the bolt is an AN4 stainless drilled for a cotterpin.
After drilling a couple of cleco holes through the area that will ultimately be cut out for the air passage, the backplate was bonded to the snorkel using epoxy thickend with Cab-O-Sil.
to be continued in part 4 of 4 . . . . . .
Dan Langhout
Old 04-25-2012, 01:11 AM
Default "alternate" Alternate Air Door part 4 of 4
Now, on to the door.
This odd looking mess is a cobbled up set of formers to make a 1/4" high standoff to mount a "bug nut" to. Think miniature hat channel.
Here's the end result after much trimming, etc. This is made from 7 plies of plain weave carbon.
Another view from the bottom side. You can clearly see the imprint from the peel ply on the mounting "feet".
Originally, I was going to make up my own carbon door. But I was concerned about my ability to carefully control the thickness of the plate (it needed to be really close to .063" and very uniform). So ultimately I wimped out and ordered a piece of .063" carbon plate, glossy on one side, from www.dragonplate.com. After drilling the pivot hole, and then laying out and cutting the door, here's a shot of the pivot reinforcement and standoff getting bonded. The bonding is to the "textured" side of the dragon plate. The smooth shiny side is down towards the smooth shiny surface of the backplate. In retrospect, the pivot reinforcement probably isn't needed. I just wanted to have more "bearing" surface on the pivot bolt.
Speaking of the pivot bolt. I'm using two wave springs between washers under the pivot nut. This ensures the door stays in contact with the backplate surface with no rattles and provides a bit of adjustable "drag" to the door movement.
So - here is the (mostly) final product.
The door works really well - it can be opened and closed all day from the cockpit. The plane isn't flying yet so it remains to be seen if this is really an "improvement" or not. I enjoyed doing it though and hope these posts at least give others some ideas.
UPDATE: 12-Nov-2021 I now have 7-1/2 years and 827 hrs on the plane and everything seems fine with the door. Still works fine - no failures. Haven't had to use it in anger thank goodness!
Interesting tidbit - I have played with opening and closing the door in flight. Manifold pressure drops 0.2 inches with the door open.
Dan Langhout
Last edited by Dan Langhout : 11-12-2021 at 09:23 PM. Reason: update with flight experience
Old 04-25-2012, 07:07 AM
DanH's Avatar
DanH DanH is offline
I'm impressed.....really clever fabrication.
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-25-2012, 07:32 AM
Walt's Avatar
Walt Walt is offline
Super nice Dan, thanks for revealing the secret process
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 04-25-2012, 08:01 AM
AirbusPilot AirbusPilot is offline
Wow amazing!!!
Fernando Abasolo
Santiago Chile
SubSonex waiting for tailkit to arrive
Flying phase II RV-8 (SCSE) Serial Number 83290, Tail Number CC-AJC
Flying RV-8 (SCTB) Phase II 600 hours and counting since February 22nd 2010
Serial Number 82727, Tail Number CC-PXG
Lyc. IO-360, Hartzell Prop
VAF #2056
EAA Member 774981
Old 04-25-2012, 08:46 AM
DOX8 DOX8 is offline
VERY nice! For a minute there I thought I was reading the COZY forum.
Jeff Wellum
EAA Chapter 83 Secretary
RV8 QB
Emp complete
Working on wings
Old 04-25-2012, 09:16 AM
William Slaughter's Avatar
William Slaughter William Slaughter is offline
Default Thanks for sharing - I guess.
Really nice design and fabrication! Looks like I just inherited a new sub-project, which I need like another hole in the head at the rate I'm progressing.
Seriously though, thanks for taking the extra time to document this beautiful work.
William Slaughter
Houston, TX
RV-8QB
Old 04-25-2012, 10:38 AM
Default Thanks . . . . . .
. . . . . for the kind words! The only problem with these "improvements" is that each one pushes the plane completion time out a couple of weeks (or months).
Dan Langhout
