  #21
Old 12-09-2011, 10:40 AM
gblwy's Avatar
gblwy gblwy is offline
Default Wiring the camera
I put a tail video cable in from day one. A short length runs up the fin to a bracket I installed in the fin cap, which has nutplates instead of rivets for easy removal. There's a small hole in the top for a ring mount around the camera. The mount is screwed to the bracket. I can remove in five minutes or so and put a grommet in the hole in the fin cap.
A second video cable runs from a recorder mounted in the cockpit through the tunnel with all of the other wires, and emerges through a small hole in the tailcone under the fin, where it attaches to the fin cable.
I can also mount the camera on a bracket inside the cockpit, on the rollbar. This is fine when flying solo, but is obstructed with a passenger on board.
Cheers...Keith
Old 12-09-2011, 01:33 PM
gblwy's Avatar
Default Landing at Marina di Campo, Elba, Italy
Need a full wallet for this one. $120 for landing and overnight parking. For that you get to drive your own stakes into a patch of sandy earth. And $15.5 for a gallon of avgas. Welcome to the Eurozone!
http://youtu.be/_FYv045auC4
Cheers...Keith
Old 12-09-2011, 02:00 PM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
Wonderful sharing of the trip with us, thanks a bunch. I was particularly thrilled by the videos you took, AWESOME! I am dfinitely adding a video cable to the fin top in my build too, I have never seen better inflight shots.!
I would love to see a photo or two of how you mounted it on the fin and tell us more about the camera you used. I want to duplicate that camera effect.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
RV12 built and flying
Old 12-09-2011, 02:56 PM
gblwy's Avatar
Default Landing at Gap/Tallard, French Alps
Gap is a major GA field in the Alps, with lots of parachuting, gliding, flexwing and fixed wing flying going on simultaneously. Circuit is interesting. I'm following another plane, so having to do a larger circuit than I would otherwise do in the restricted space available.
http://youtu.be/0NFhc__pzKY
Cheers...Keith
Old 12-09-2011, 03:18 PM
gblwy's Avatar
Default Video kit
This is the stuff I have been using. It's a couple of years old now, so not HD, but nonetheless quite good quality. Many videos I have seen chop a rotating prop into horizontal segments. At least mine goes round, though sometimes it stops or goes backwards ;-)
I have had difficulty with the power cable into the recorder, resulting in the recorder switching itself off if anyone touches the cable. I powered it with a spur off the cigarette lighter socket. You need to remember to unplug the recorder, as this is an unswitched circuit straight off the ship's battery.
http://www.fastfilms.co.uk/hqr-2-sol...o-recorder.php
http://www.fastfilms.co.uk/sony-hq2-bullet-camera.php
(Taken in the early days with leaking brake system, air bubbles etc)
I have a 16 gb card in the recorder which is good for 4 hours recording, which is the endurance of the plane at a reasonable cruise speed. It has a small remote control unit which I keep in the pocket on the sidewall (I have the full trim package).
Cheers...Keith
Old 12-09-2011, 03:35 PM
Interesting flight report and neat video's, Keith.
Thanks for posting...
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 05-14-2016, 03:22 PM
HansLab HansLab is offline
Default dimensions
Flying weather was not that good this week zo I spend some time carpeting. It seems not possible to upload pics via this reply, so I'll make a new post with all dimensions this bagage-box: thanks to Keith!
Keep them flying!!!
Hans Labruyere
build & sold project Kitfox IV
Project bought & flying RV12 #120742
Donation 2021 paid
