Old 12-07-2011, 02:54 PM
Cadstat's Avatar
Cadstat Cadstat is offline
Default Conditional inspection - week 4
The conditional inspection turned up many issues.
400 for the A&P inspection plus repairs + prop seal totaled 1055.00
I pulled the tanks for the gas leaks and prosealed the senders.
The ELT was shot so I ordered a new one that arrived two days ago. 179.00
The transponder had a bulb burned out and with the 2 year certification 265.00
Broken air box top aluminum plate and rivets 35.00
They ran the engine without the spinner and centrifucal force bent the extended flanges out so more down time waiting for a new spinner backer plate.
And the hanger went to 9 below zero one night so slow going.
I went EXP because the GA A/C was so expensive. So much for that plan!
John D. Artz, EAA 71811, 100+ Young Eagle flts
Adopted Dave's 6A
MXL Ultralight, only bleeding after 3 landings
Scorpion Two Helicopter, big mistake
PA-28 and 210E Centurion
Old 12-07-2011, 04:19 PM
G Sharp G Sharp is offline
John,
Where did you find ELT for $ 179 ?
Gary gsharp@dybb.com
Old 12-07-2011, 04:26 PM
Mel's Avatar
Mel Mel is online now
Aircraft Spruce has an Ameri-King AK-450 for $150.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-07-2011, 04:55 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
It's hard for me to imagine that you consider $1,500 expensive for a condition inspection after having owned a C210. That's just $1.50 in airplane dollars and really seems pretty reasonable.
I just can't figure out how the spinner back plate got bent. My engine has been run to pretty high RPMs a couple of times that way with no problems.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 12-07-2011, 05:50 PM
Walt's Avatar
Walt Walt is online now
Maintaining an airplane costs $$, no way around that. I just got done with a condition inspection on an 8 and with parts and repairs it was around $2800... the owner was tickled pink with the bill and said that even with all the repairs I did it it was still the cheapest annual he ever had and cost him about 1/10th what the annuals normally cost him on his certified birds
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 12-07-2011, 06:04 PM
Vern's Avatar
Vern Vern is offline
Smile Non repeating items
Next year should be much cheaper as these items could be considered to be getting your plane in shape. Next year should be cheaper. Especially if you take care of all mx yourself.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 12-07-2011, 07:19 PM
hydroguy2's Avatar
I went experimental for the fun of it. Today I finished Aurora's first "Condition Inspection". The two of us only managed to log 91hrs in the first year, but we had fun getting to know each other. The condition inspection was a first for me, I took my time(1 week) going over everything with a fine tooth comb and even had a A&P friend help me do my first compression check and look over the firewall forward stuff. Squawks were 1 loose exhaust hanger, 3 loose baffle screws and both gearleg fairings were had cracked at the upper clamps. Total cost <$5 worth of fiberglass stuff. Also I installed a little AL tape to block 1/3 of the oil cooler. All fixed up and still daylight out SO might as well celebrate the occasion with a
Sunset Flight
then tuck her away until our next rendezvous....tomorrow's looking promising
Life is good and experimentals are fun
