dustin_96
Member
I will be having 2 landing lights in each wing. How should this be wired? Should each light be on its own circuit back to the switch or can one circuit be used for each wing? Is the wire provided in the harness (I believe it is 16 ga.) sufficient to carry both loads? It looks like the current draw for the lights I'm using is 3.2a+4.0a=7.2a in each wing.
Thanks!
Thanks!
