Washers
I wonder if you measured the thickness of a washer, then find the threads per inch on the pressure adjustment bolt if that would be close? 18 threads per inch would be .055 per turn, so 4 turns would be .22 inches. So how thick is your washer? Any math guys please check out my idea????
