VAF on Twitter:
@VansAirForceNet
Old 09-05-2022, 04:44 PM
mulde35d's Avatar
mulde35d mulde35d is offline
Default Fiberglass Tool Trifecta
I must say, I have gone through a lot of sandpaper while working on fiberglass, but no more. Decided to try a couple new tools and must admit that these 3 tools in combination with each other are absolutely spectacular.
Dremel Saw-Max: Cuts through fiberglass like butter. has so much torque it twists in your hand when it starts (start it off the workpiece) and never gets bogged down in the cut.
Oscillating tool (Dewalt): with 60 grit sandpaper this thing shaves down edges like a champ.
Permagrit Wedge Block: Just like sandpaper wrapped around a 2x4 but doesn't wear out (hasn't yet at least) and doesn't scrape up your hand over time like the stuff wrapped around a 2x4.
Highly recommend these 3 tools for fiberglass work.
Jon
RV-14A Sold
RV-10 Empennage - Complete
Wings - Complete
Fuselage - In Progress
Finish - On Order
Old 09-05-2022, 05:16 PM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Nice.
I've discovered that if I use conventional wrap-around sanding blocks much, I cannot use my fingerprint scanner to log into my MacBook until the ridges on my fingertip grow back.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD - 80 hours
66 years running stock DNA
Old 09-05-2022, 05:58 PM
MacCool's Avatar
MacCool MacCool is online now
I agree, I found my Milwaukee oscillating tool to be absolutely invaluable in redoing my wheel pants recently.
RV-9A, 2011, bought flying
IO-320D1A (factory new), C/S
Dual Pmags
IFR equipped
AFS 5400/3500, G5, IFD440 navigator,
bunch of other stuff
Old 09-05-2022, 07:07 PM
wirejock's Avatar
wirejock wirejock is offline
Default Tools
I use them as well. Plus my Ryobi Angle Grinder with a cut off wheel, Ryobi Random Orbital (two) and Dremel.
I keep two grits on the random orbitals so I dont have to fish.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
Old 09-08-2022, 10:21 PM
Weefle's Avatar
Weefle Weefle is offline
Default Diamond grit
If you add diamond grit blades to your oscillating tool then watch the white stuff fly. Gets into the corners and lasts longer than sandpaper as well.
____________________________________________
RV-10 in progress
CGMMD reserved
Dues paid till 2024
