I’m looking for some sort of rubber trim that I can use to cover the joint between the inside of the canopy and the frame. The rv4 canopy is so small that it is hard to get access to do a really clean job on the glue line between the canopy and the round tubing of the canopy frame. Some sort of trim or automotive gasket would clean it up. Have any of you guys found something that works well? I thought I saw a post a while back where someone used rubber tubing but I can’t seem to find it. Any suggestions welcome.
