  #21
Old 05-21-2022, 06:39 PM
Walt's Avatar
Walt Walt is offline
Originally Posted by lipper03 View Post
I did get a change to talk to Larry at McFarland today, and both 9 and 12 are acceptable. The 12 does have a shorter recommenced TBO and may see bearing wear more then a 9, but no safety of flight or RPM or other limitations for an RV14A with a EXP119. I'm checking back with Vans to make sure I understand the color options and delivery assembly vs ordering with McFarland. Thanks Walt for the suggestion!
Donít forget the PMAG limitation with the -12, and the extra weight of the -9 would help with CG.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Old 05-21-2022, 06:47 PM
dmattmul dmattmul is offline
Default Composite 3 blade
Iím not sure who started the ďif you go composite blade route you will be aft heavy on the 14Ē but seems a myth. Vans designed the 14 with a 360 and that weighs 18 lbs less than the original IO390. I donít know what the EXP 390 weighs but as one builder points out adding an accessory case increases the weight. Not to mention adding a stand-by alternator. My best landings are made when I have my bicycles in the baggage area and tools. Check your W@B calculations assuming different prop combinations.
RV-14A QB builds, Lycoming 390 Thunderbolt arrived July 2019, Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 300-72, Earth-X batteries, Parts became a real airplane 8/15/2020.
Started RV-10 Nov 2020. Empennage arrived (Built) Working on QB kits. Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 3 blade, Earth-X batteries, real airplane hopefully early 2024. Paid subscriber and more. (Worth every dollar contributed).
Old 08-13-2022, 06:03 PM
Default Please review
Just did my W&B and inserted loads that would shift CG furthest aft. Let me know if you see any errors.
Old 08-13-2022, 06:05 PM
Finished W&B after paint. Let me know if anyone sees an issue. Of course I can't fly acro but why would I with baggage (And my wife on board)
