I'm just in the final stages of planning my panel. I'm going to install a few 12v 20ma LEDs on the panel to alert for things like Canopy unlatched and Low Oil Pressure.
It would be nice to have this show on the G3X as well as the LED light up.
Does anyone know if it's possible to wire these LEDs inline (in series) with the 'Discrete Input' so that the LED lights up as the signal is passed to the G3X?
I believe the discrete inputs are Active Low which I assume would mean the positive leg of the LED goes to the discrete input and the negative to ground. But will this configuration activate the LED?
