BobbyLucas
Has anyone else come across scribe lines like this on the upper tailcone fairing? Click on pic to enlarge. And sorry, I'm not a photographer.
Response from Van's:
"I’m told the mold was re-scribed because the initial trim was too aggressive for some builders and you should use the more conservative trim lines, you can always remove more if needed."
That doesn't add up in my mind given that the double scribe lines overlap each other at the corners, are non-parallel in some areas, missing in other areas, final-trimmed to the scribe line in one area, etc. At any rate, the response implies that all of the parts shipped after the mold change look like this? My empennage kit was ordered 11/2019.
Lesson learned: I should have spent more time considering this issue before jumping in with the cutting tools. "I cut it twice and it's still too short!" Hopefully I can still make the part work and look good.
