Old 02-26-2021, 10:56 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Congratulations!!!
Scott, congrats on finding the problem, and thanks for reporting back----you might save someone else a bit of heartache in the future.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-27-2021, 06:21 AM
Mel's Avatar
Mel Mel is offline
Default WAIT..........
Originally Posted by flipfloplife View Post
Solved.
Not sure exactly how it got overlooked --- but I added a stub antenna (plugs into the TN20, not the control head for the next person -- that connection is a TNC connection, screw type ---- then a BNC on the antenna end in my case).
Someone had thought of it at some point because there was a hole in the fuselage filled with a plug.
Quick trip to the parts department at the orange store for fitments and I was in business. Thanks for getting me pointed in the right direction!
The stub antenna plugs into the TT22, remote transponder. Not the TN72.
The GPS, puck, antenna plugs into the TN72. I'm pretty sure you have it right. Trig made the antenna connections different to avoid confusion.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
