Hi
Question on the Battery Amps value on my Dynon HDX- with the charger attached. It reads ‘-3’ with the indicator at the bottom of the green band of the widget.
Battery is charging since the Battery Volts value is increasing.
Assuming you’ve got the charger connected to the battery terminals, the Dynon can’t tell the difference between the battery discharging to power the Dynon or the charger is providing the current.
