Just a quick thank you to Scott McDaniels and Van’s for the great fuel tank video.
It was released when I had only one rib to go on each tank but I thought I would try the fuel tube trick for applying Proseal on the shop heads. The only thing I did different was used a flared tube and since I had the sealant in a big syringe I just squeezed a little bit in the end of the tube each time.
Scott demonstrating the fuel tube trick
It worked great!
Thanks for the support Van’s. I’ll be following the baffle install section of the video after Christmas and looking forward to one on fuel tank leak testing!
It worked great!
