Go Back   VAF Forums > Model Specific > RV-6/6A
Old 06-25-2020, 09:02 AM
ebackscheider ebackscheider is offline
Default Manual to Electric Flap Conversion
Hi all, looking to add electric flaps. I did not build though. How hard is this conversion? I will be buying the full kit with new weldment.
Thanks All!
Eric Backscheider
2020 Dues Paid!
RV6 - N6014Y - Flying
Pitts S2B - 245JH - Sold
CFI - Acro in the 6 Rocks!
StopFlyingScared.com
Old 06-25-2020, 11:23 AM
gasman gasman is online now
Thanks All!
With the full kit, you should be able to follow the same install for a 7. Look up some 7 builders logs.
This is not a complicated task..... And you can sell your manual weldment and all manual parts here on =VAF=.
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
Old 06-25-2020, 11:29 AM
Sam Buchanan's Avatar
been here awhile
Here are the notes from my manual to electric conversion on the RV-6:
http://home.hiwaay.net/~sbuc/journal/fuse7.html#flaps
As far as difficulty goes, it is a straight-forward conversion for an RV builder. A non-builder, however, probably will not have the riveting tools and skills needed for the conversion.
Sam Buchanan
RV-6
Old 06-25-2020, 02:10 PM
Jpm757's Avatar
Jpm757 Jpm757 is offline
I believe Van offered a retrofit kit back when the electric flaps became available. There are some people out there that would be interested in your old manual weldment and parts.
I personally prefer the manual setup which I fitted to my-7, lighter and simpler. Also allows easier access to baggage compartment in flight.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
(KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis, floats.
Building Javron Super Cub.
2020 dues gladly paid.
Old 06-25-2020, 03:13 PM
Sam, you are correct. I have no riveting tools. I was afraid of that.
Eric Backscheider
2020 Dues Paid!
Old 06-25-2020, 03:56 PM
NewbRVator NewbRVator is offline
Why convert? Manual flaps are good aren?t they?
21 dues paid member since 2018
RV6A
Old 06-26-2020, 08:10 AM
The same reason Sam did. My passengers are wider than the seat. It will just make life easier. Yes, the current ones work perfectly.
Eric Backscheider
2020 Dues Paid!
Old 06-26-2020, 08:14 AM
Substitute Cherrymax pop rivets and save yourself the trouble. Alternately, find a local builder to take care of the riveting. It shouldn't be a big job.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 06-26-2020, 08:40 AM
titanhank titanhank is offline
The best upgrade i ever did to my -6 was electric flaps. I used the the manual flap weldment and welded the supplied bracket on after cutting it off extra length per the plans. I no longer catch a pax under the chin with an elbow anymore.
Harmon Rocket #1
IO-540
10-1 pistons
1959 Piper PA22-150 Tri-Pacer
Rv7a sold
Rv6 sold
Rv4 sold
Rv3 sold
Old 06-26-2020, 09:40 AM
Eric,
I have all the riveting tools, etc needed. I can help you with it. Give me a call.
SH
RV6/2001 built/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2021
