Old 04-12-2020, 10:06 PM
vernh59 vernh59 is offline
After assembling and match drilling the fuse tail section, I disassembled for deburring, edge shaping, dimpling, etc. As I was getting the parts ready for assembly, I started looking around the shop and decided I had to do something before I began the next phase. I replaced some old wall board, painted and generally reorganized.
Sooooo much brighter. Now to get on with it.
Putting things back together. I fastened the bulkheads in place first, then the stringers. This assembly got rigid in a hurry.
This assembly almost made me wish I built an /A. Almost...
Finally have the tail cone in place. Now to start the riveting. Before I did that, I got the laser out and checked alignment again. Looking good so I started the assembly.
Finally have the tailcone riveted together up to the upper J channel.
Fly safe,
Vern
Ozark, Al
RV-7 Build No. 71139
Empennage Complete, Wings on hand
Starting Fuselage 11/15/19
https://eaabuilderslog.org?s=lhead
Exempt but gladly donating!
Old 04-16-2020, 11:48 AM
Getting started on the center section with the seat ribs. I spent some time trying to figure out the access ribs and the clearance ribs. Finally. I marked and cut the ribs as shown.
This is the completed access rib. You will want to finish attaching the reinforcing plate to the cutout rib piece before installing the nut plates.
With all the ribs cut and the rib nut plates installed I attached the ribs to the F704 aft bulkhead and the F705 bulkhead. You may notice F705 is modified for the Anti Splat Almost a 14 seat mod.
Next, the baggage area ribs are attached to F705. This takes some patience as the two ribs share clecoes in several spots AND there are small spacers in 4 spots. I found I could put a clecoe in from the front to hold the rib and spacer in place while attaching the baggage rib with another clecoe, then push the first through without loosing the spacer.
After this photo I discovered that I had mistakenly attached one rib in the wrong place, twice. This became obvious when I tried to attach the skin.
Center section skin in place. I had this assembly vertical for assembly but couldn't leave it like that for the night so I laid it back down.
Looking more like an airplane everyday.
Fly safe,
Vern
Ozark, Al
Old 04-16-2020, 06:52 PM
kentlik's Avatar
kentlik kentlik is offline
Looking good! I really liked building the center section. Easy to manage on the table.
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 04-17-2020, 09:19 PM
longranger's Avatar
Vern, if you haven?t riveted up the floor ribs yet, now is a good time to install crotch strap brackets.
Miles (VAF# 1238, Paid up as of 12/20)
RV-7 TU 904KM (reserved)
Construction Log
Empennage Album, Wings Album, Fuselage Album
Old 04-19-2020, 04:40 PM
wirejock's Avatar
wirejock wirejock is offline
Default Trim servo
Also a good time to install the trim servo stuff.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 04-21-2020, 01:03 PM
Thanks for the input guys. I really appreciate the tips. You don?t know what you don?t know.
We had some close storms and I?ve been on a generator since Sunday. Hopefully back in the shop by Friday.
Fly safe,
Vern
Ozark, Al
