billnaz
I'm dealing with an infuriatingly intermittent PTT problem. It only occurs after about an hour of flight. Failure is as if the PTT button is failing, with activation cutting in and out. I've already switched the switches with no change. I suspect a bad ground, but dread the thought of tracking that down. Any ideas from the brain trust on path to follow in trouble shooting?
