Old 10-03-2017, 07:11 AM
Saville's Avatar
Saville Saville is offline
Default Prepping the oil sump for Reiff install
Hi all,
I want to install the Reiff oil heaters on my O-360 A1A. I installed the cylinder bands last year.
The Reiff instructions say to remove any "anodizing" and paint from the sump's surface then clean with Acetone.
I confess my ignorance: are oil sumps aluminum and are they anodized?
If so what should be used to remove that?
And if you remove paint/anodizing from the sump on an area larger than the
glue surface of the heating pad, is that exposed surface now susceptible to corrosion? If so, what's the best way to seal it? Some of the Epoxy?
Flying RV-8 N880BC
2021 Dues - happily paid.
Old 12-29-2019, 04:54 PM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
I bought myself a Christmas present; an insulated engine cover from Aircraftcovers.com.
The red bag is the storage bag.
I'm really impressed by the quality and fit (even a protrusion for the exhaust). The Reiff preheater is switched by a WiFi switch (DRH-704 ~ €35,-). Will take some temperature measurements next week.
PH-BZT
MyKitlog
Old 12-30-2019, 07:58 AM
The reflective N-number is just the icing on a very nice cake.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Last article: "Gonna Finish This Sucker" (Kitplanes)
Waiting for the avionics kit (backordered: chip shortage)
Old 12-30-2019, 08:52 AM
Dave12 Dave12 is offline
Nice floor! Can you tell us about your WiFi switch?
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Old 12-30-2019, 10:35 AM
Gagarin737's Avatar
For just $20,- extra ;-) The cover is not cheap but it's really a beautiful cover
I initially was looking for a switch with a GSM sim. Thoose switches are more expensive and you need an extra sim card. The company selling thoose switches came with this solution. You only need Wifi in the hangar, no ports forwarding or oher network stuff etc. The switch is controlled with an IOS/Android app. This switch is 240V btw. Works awesome
PH-BZT
MyKitlog
Old 12-30-2019, 01:14 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
I?ll butt in here?. I have a cell phone relay switch because I can?t get a WiFi signal at the hanger. If you?re one of the lucky ones who has a strong WiFi signal then I suspect this https://www.ebay.com/itm/Sonoff-Swit...8AAOSwj~VcmErZ would work just fine. Rated at 2200 watts so it will operate an engine preheater.
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 750
Old 12-31-2019, 07:14 AM
BobbyLucas's Avatar
BobbyLucas BobbyLucas is offline
Personally for something like this I'd spend a couple extra bucks to get a trusted name brand from a reputable source, and look for the UL listing. Just watch Big Clive on YouTube tear down some of these eBay "Chinese automatic house ignitors," as he calls them.
Bobby Steinmetz
Van Buren TWP, MI
Student Pilot, Mechanical Engineer, Donating Member
RV-12iS #121228
  • My opinions are JUST my opinions, not facts
  • Regardless of phrasing or colorfulness, my opinion does not imply that any opposing opinions are wrong or ANY less valid than my own
  • Respect people by giving your own opinion without attacking or belittling others
  • Passive-aggressive is not better than overt-aggressive
  • When I fail to meet these standards, please call me out, gently
