Old 05-20-2019, 01:04 PM
Roarks's Avatar
Roarks Roarks is offline
Default HS-702 with the HS-00003 minimum edge distance.
So I wasn't sure if this is the minimum edge distance that everyone was talking about... sure enough it is. Thanks Vans for the clarification.
"The two holes directly above and below the notch are known to have short edge distance and accepted by the engineers, not a problem."
And if you look real close... you will see why I just spent $20 getting another HS-702.
I think what is going to take the most time is screwing up on a Saturday night, waiting to hear back from tech support on Monday, and ordering parts that take another 3 days.
Old 05-20-2019, 05:58 PM
nzrv8's Avatar
nzrv8 nzrv8 is offline
Good to see you approaching your build in the right way - Being cautious and talking to Van's when unsure.
It's a difficult intro to an RV build - working on the first real structural part, where one hole drilled through 3 or 4 layers can ruin your day. I have a few (4!) spare HS-702's, not to mention a box full of front spar reinforcements..
Something I found interesting - having built two complete HS's - On the non-SB HS front spar there aren't any areas where lower than normal edge distances are acceptable, yet on the SB version there are multiple areas where less than perfect edge distances are approved by Van's. Even on critical structures, less than perfect edge distances are sometimes acceptable with Van's approval, indeed sometimes unavoidable. But always check with Van's!
Good luck with the rest of the build - This front spar area is the initiation!
Hugh
Paid up - Sep 2021
Old 05-21-2019, 06:04 PM
wirejock's Avatar
wirejock wirejock is offline
Default Relief notch
The old plans had those relief notch pilot holes further toward the vertex. Wonder why Vans moved them?
Easier to file away material than replace it.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 05-21-2019, 07:25 PM
Girraf Girraf is offline
Did you enlarge the wrong hole? Why aren?t both the big holes for the relief notch not tangent to your vertical line there? Bottom one looks ok but the top on has me puzzled
Vintage Cherokee 160
RV-7:
Empennage complete
SB Wings to QB stage
Fuselage in progress
Finish kit/Engine/Prop Ordered
Old 05-22-2019, 10:28 AM
Roarks's Avatar
Originally Posted by Girraf View Post
Did you enlarge the wrong hole? Why aren’t both the big holes for the relief notch not tangent to your vertical line there? Bottom one looks ok but the top on has me puzzled
Sure did. New one showing up today.
Old 06-08-2019, 12:58 AM
Roarks's Avatar
So... I have been seized up past week doing day job work... but also having what one of my engineering buddies affectionately calls a "helmet fire" when it comes to dimples.
The large plate on the right is representative of every dimple I have ever made... just kinda looks not great. can kind of see up under the rivet head a bit too.
I Just watched cleavelands video https://www.youtube.com/watch?v=Qo9QCMaNSoA
So basically I'm weak and need to put a handle extension on my DRDT-2.
Plate on the left... Holy shiitake mushrooms batman! I finally did it.
-Also my back rivet plate and back rivet set had disappeared... Finally found it. So... I'm clear to proceed!
EDIT: My single piston CP214 could not dimple as good as the DRDT-2
Old 06-09-2019, 06:49 PM
I was under dimpling when I started too. I didn't get the help I needed until another builder pointed out my error, but fortunately for me I hadn't started riveted more than a couple skin rivets at the time. He demonstrated that a fully dimpled hole will leave witness rings like a bullseye around the dimple which is another indicator to observe.
It should also be noted that Exp. Aero (maker of the DRDT-2) says the it is impossible to over dimple with that tool. I personally don't think its possible to over dimple with any common airplane building tool but what do I know...I'm just an amateur.
RV-7:
Empennage complete
Old 08-19-2019, 01:21 AM
Roarks's Avatar
So I haven't done much since Phoenix went 100°F+.
BUT! This was my RV8 mini project for this weekend. AC in the garage.
Old 04-10-2020, 12:56 PM
Roarks's Avatar
So... I have been vapor locked on what to do for priming because of product selection and skills/equipment to spray.
I finally got my 60 gallon compressor set up which was a major hold up to get the CFM for my FLG-4 (FLG-671 waterborne) spray gun. The compressor was a craigslist find for $100 It needed a new check valve, a good cleaning, and a quart of oil... so not a bad gig. It plugs right into my welder extension cord from the dryer so I'm happy as a clam.
So I bought Stewart Systems EkoPrime because I liked that it's a 1 part, and waterbased. Then I saw this https://www.youtube.com/watch?v=rgjXVCwV3V8&t=191s
Made me feel 110% better about the whole thing until I got to reading the comments. Apparently not the greatest for wear areas and not solvent resistant.
I'm wanting to prime everything. Inside and out like a production aircraft. Stewart systems suggested prime everything with Ekoprime, then ekopoxy the cockpit and outside after assembly. Thoughts?
The other option is I have https://www.skygeek.com/u-s-paint-10...compliant.html. From doing a touchup job on a Cessna 210.
Old 04-11-2020, 12:35 AM
PaulvS's Avatar
PaulvS PaulvS is offline
Default Primer
There's endless opinions on primer. Here's mine, based on what you have:
1. Prime the bulkheads, stringers, ribs etc. and all the other small parts with the water based one pack primer, because it is easy to clean up and no waste in small batches.
2. Prime the insides of the skins with the 2 pack Akzo.
3. Prime the outside skins with whatever is compatible with the topcoat you decide to use.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
