  #11
Old 02-15-2019, 03:16 PM
rongawer rongawer is offline
Congratulations Justin!
Ron Gawer
- RV10, N762G, Build in progress.
- Several others that are now just great memories for me.
Old 02-15-2019, 11:03 PM
dreed dreed is offline
Congratulations!
Dan Reed
Camas, WA
RV-7A - N167DR
First flight 5/25/2021
Phase 1
2018/19/20 VAF dues paid
Old 02-17-2019, 07:39 AM
T.O.Craig T.O.Craig is offline
Congratulations Justin. We hope to be there in a month or so!!
Craig Rufi
FLYING NOW AFTER 13+ YEARS. NICE FLYING AIRCRAFT!!
RV-10/Empennage/Wings/QB Fuselage/Wiring/Doors done finally, Cowling done. Stein panel complete, and connecting all those wires :-))Thousand Oaks, Ca. Dues paid for 2019
Old 02-19-2019, 05:08 PM
ppilotmike's Avatar
Default Way to go!
I'm right behind you..by a couple of years.
Seems my pace is slow..
Mike Rettig
VAF Dues Current
RV-10 - Working on engine / prop installation
Old 02-26-2019, 08:37 AM
AviatorJ AviatorJ is offline
Originally Posted by N941WR View Post
Good luck sorting out the oil temperature issue and completing your 40 hours!
I could probably be the poster child of why to keep the build simple. Although whats the fun in that...
On my oil temps I worked on my baffle sealing and then did a long 2 hour+ flight with no issues. Even adjusted my damper and got the temps to adjust accordingly. So it must have been the seals.... nope.
On the next long flight, again 2 hours + about an hour and a half in the temps started rising again. I slowed down and circled the airport for about 15 mins, long enough to see the temps stabilize at 226 and long enough to get 5 hours on the engine.
Doing the 5 hour oil change I expected to see a cowl seal pushed in or a big hole or something. I found nothing. After the oil change I decided to stick my hand down the oil cooler scat tube to see if something was shoved in there. As I reached in I inadvertently was able to push the butterfly valve close. Meaning that force air was probably doing the same thing.
My fault though in the way I had the actuator arm clocked. Won't go into the details but it was an easy fix so I'm looking forward to future flights with no oil issues!
Justin
RV-10, N10JW
Flying since 2/14/2019
http://operationrv10.blogspot.com/
Old 04-18-2019, 08:56 AM
It's not the first flight, but it's still a Phase I take off! A friend of mine recorded it and I forgot about it.
https://youtu.be/PiTGLzcAAJU
Justin
RV-10, N10JW
Old 04-18-2019, 09:52 AM
Electrogunner Electrogunner is offline
Default Sound
Love that sound. Had to play it back 3 times.
RV10 N620RV BUILT, FLEW, SOLD
RV10 N821BS coming soon
Old 04-19-2019, 07:27 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Congrats Justin!!
Bill Peyton
RV-10 - 1285 hours
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 04-19-2019, 08:35 AM
1001001's Avatar
1001001 1001001 is offline
Congratulations! It must be a great feeling!
I am a bit farther behind but still chugging along. Can?t wait. Every first flight offers more encouragement to other builders.
Old 04-19-2019, 09:20 AM
leok leok is offline
Default A Big Day
Congratulations
I hope to join you in the next few months!
Building started Oct 5th 2014, Flying since 1/16/2020
http://www.mykitlog.com/leok
RV Hotel, come by and visit if you're in town
Dues paid 2020
