Old 06-16-2007, 06:29 PM
Question trio a/p
Why doesn't Trio offer a "headstart" package as others do. It would be great if one could buy just the "hardware" for my a/p, alt/hold etc instead of forking over for everything at once, where the brains sit in boxes for two years atrophying.
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
Old 06-16-2007, 07:58 PM
Sam Buchanan's Avatar
been here awhile
Lorne, I'm pretty sure you can purchase just the servos and wiring harnesses for the Trio EZ systems. That would allow you to do all the fabbing of the mounts and wire runs. Mounting the control heads in the panel is a job that only takes a few minutes once the holes are cut (all the templates and dimensions are available on the Trio site).
But......to get the real scoop, call the three amigos at Trio for first-hand info. They are a great bunch to work with and will get you headed in the right direction.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 06-16-2007, 08:14 PM
Radomir's Avatar
Radomir Radomir is offline
You can get the servo alone here:
http://www.trioavionics.com/gs_servo.htm
and harness here:
http://www.trioavionics.com/ezp_harness.htm
Don't know if they have any additional mounting hardware or if you have to fabricate that yourself.
Radomir
RV-7A sold
Old 06-16-2007, 09:27 PM
Steve Ashby's Avatar
Steve Ashby Steve Ashby is offline
Default The Trio Folks will sell you just the servos
I spoke to the Trio folks at OSH last year and they recommended that I install the servo before closing out the wing. They offered to sell me just the servo and I could purchase the rest later. I was a little leary, but then he said I would get a money back guarantee, and that I could return it for a full refund, even if I did not like the color. He even put that in writing. I was sold. I have since purchased another servo for the pitch autopilot. These folks are great to deal with.
Steve Ashby
Stone Mountain, GA
N184RW (reserved)
RV-8A
YIO-360 180 hp Lycoming
Hartzell Blended Airfoil Prop
Engine Hung
Old 06-17-2007, 06:00 AM
videobobk's Avatar
videobobk videobobk is offline
Default Trio service
I purchased my wing servo first, then later the control head. Not only that, when I had a problem with tracking (which turned out to be the GPS software,) they sent me a new control head not questions asked, just to make sure it wasn't their unit causing the problem. GREAT service and excellent product. Give 'em a call!
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 06-17-2007, 02:26 PM
Vern's Avatar
Vern Vern is offline
Default Trio Customer Service:outstanding!
Call them! My experience is they have the best customer service in the aviation business!
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 06-17-2007, 07:21 PM
Default thanks
Well, thanks for the info. I'll give them a call. I suspect that most of the dollars are in the servos and hardware and not in the panel heads (just buttons and switches)
regards,
VAF...where else do you need to go?
Lorne
RV 7a tip-up
Old 06-17-2007, 09:46 PM
been here awhile
A little research on the Trio web site will reveal that the cost of the servo is slightly less than half the cost of the entire system. The control heads are much more than just switches and buttons since they include the processors, display, AHRS sensor circuit boards, pitot/static sensors and proprietary software...and probably some more stuff.
Sam Buchanan
RV-6
Old 06-25-2007, 11:52 PM
Default trio, what does the future hold?
I placed my order for the EZ Pilot autopilot and EZ-2 altitude control w/auto trim. But held off ordering the control heads. Trio said that there are some "very interesting" things coming out of Trio in January. I suspect they will be tight lipped at Airventure. We talked about the changes and advancements in experimental avionics. He cinched it for me when he said that they have shipped over a hundred servos sans control heads. I'm two or three years from needing them anyway. So, as I've read in another post about buying everthing you could think of now. Gee, if it's going to sit in a box for a few years and the techlology is advancing...I think it's a no brainer. For a few more dollars (maybe), wait and plug in the latest software,product advancement your money can buy.
I'm just sayin'
Lorne
RV 7a tip-up
