Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #41
Old 12-25-2018, 02:06 PM
snopercod's Avatar
Originally Posted by kismet View Post
I plan to upgrade crush plate and extension to larger surface area and sort it all out by talking to Craig Catto.
Craig will want you to order a 7" dia extension with 7/16" prop bolts from www.sabermfg.com.
If you order the three-blade, it will be smoother and look sexy, but your glide ratio will suffer if you care about that.
(2020 dues paid)
Old 12-26-2018, 06:01 AM
pa38112 pa38112 is offline
Kismet, are you out of the woods and in your way home?
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 12-26-2018, 07:08 AM
sailvi767 sailvi767 is online now
Originally Posted by snopercod View Post
Looking at the photos, the Great American prop that I have been flying behind for years looks a lot worse than yours. But if you're not comfortable flying behind it, then do whatever you think is right.
I would consider replacing the prop. If it failed in flight the outcome is likely to be fatal.
Old 12-26-2018, 10:24 AM
snopercod's Avatar
Oh, would you "safer than thou" guys just stop it? The ugly parts of my Great American prop are just cosmetic, not structural and the Great American props used micro-laminations rather then just three or four as in the OPs case - a much more sound way of building a prop. I've flown across the Country with this prop and even (accidentally) had it up to 3,000 RPM not long ago. If the prop were going to fail, it would have done so then. My engine didn't fly apart either. Not all of us can afford to shell out $2,500 for a new prop every time we see a minor, cosmetic defect.
(2020 dues paid)
Old 12-26-2018, 06:41 PM
kismet kismet is offline
Default Resolved
Alright boys and girls,
Flew the pacesetter without a spinner today (no backplate). Honestly, I think it's almost the same speed with the little "test pilot" wind triangle I did. Regardless, climbs amazingly and ran smooth enough by just leaving my existing dynamic balancing washers where they were.
Not bad.
See the pictures: https://www.flickr.com/photos/brooks...7676935626358/
Brooks
[SOLD] 1994 N134JB RV-6, O-320, Catto 3-blade
1976 Skybolt, IO-540, Hartzell 3-blade C/S
KLMO
www.brooksmershon.com
Old 12-26-2018, 07:19 PM
snopercod's Avatar
Awesome. You did good.
(2020 dues paid)
Old 12-26-2018, 08:04 PM
I am going by your statement that your prop is the worse than the OP?s which is not just cosmetic.
Old 12-26-2018, 08:54 PM
Sam Buchanan's Avatar
been here awhile
Not bad.
Watch the CHT's in case the absence of a spinner disrupts airflow into the cowl.
Sam Buchanan
RV-6
Old 12-26-2018, 09:05 PM
I agree; Pacesetter made really good props. And if performance is similar to your previous prop, that's a real bonus; it's rare to get a good match when you're forced by circumstance to take whatever is available.
Charlie
Old 12-27-2018, 08:09 AM
snopercod's Avatar
I wonder why so many propeller manufacturers have gone out of business. Great American, Aymar-Demuth, Pacesetter...
(2020 dues paid)
