  #41
Old 03-24-2018, 08:15 PM
kiljoy's Avatar
kiljoy kiljoy is offline
Default Can't put this piece on a shelf
I'm deep into the tailcone. This is a fun chapter. Thank you Van's for the excellently prepared wiring harnesses!
Dues paid (2020)
RV-14 #140394
Empennage - done(ish)
Wings - done(ish)
Fuselage - done(ish)
Finishing Kit - Somewhere in there
YouTube Build Channel
Old 03-25-2018, 07:52 AM
Erimo's Avatar
Erimo Erimo is offline
Originally Posted by MED View Post
Thanks, Eric, I know. To get the axle mounting holes for the wheel pants horizontal, I had to swap sides from the way the factory had the caliper set up. Fortunately, as you point out, the bleed screws can be reversed.
I know, I had the same situation
Otherwise, what fitting did you install on the bottom of the fuselage to connect to upper end of brake hose ?
The AN816-2D don't match with the fairings. So I'll order AN823-2D. They'll fit better the gear legs.
Eric
RV 14A - #140252 - Flying
France
2021 Dues Paid
Old 03-25-2018, 05:04 PM
MED MED is offline
I had planned to use AN816-3D, but I haven't installed them, yet. Thanks for the tip about the AN823-2D. I'll see what fits best.
MED
140236
N435MD
Miss March 2020
Old 03-26-2018, 06:53 AM
Erimo's Avatar
You are right, it seems to be 3D.
The straight fitting and hose interfere with fairings. i think an angle fitting is better.
Eric
France
2021 Dues Paid
Old 03-26-2018, 09:57 PM
didja didja is offline
still trying to figure out how to post pics so that its not a link! Computer genius, or even literate, I am not! lol!
Scott Emerson
RV-14a Kit# 140432
Working on: Fuselage
Construction log: https://www.youtube.com/channel/UCaZ...Uv2rlQsHtdRmmg
Donation Paid (military)
Old 03-27-2018, 06:55 AM
MED MED is offline
Try tinypic.
MED
140236
N435MD
Miss March 2020
Old 03-28-2018, 02:47 PM
MED MED is offline
Default RV-14A Engine On
Engine on now.
MED
140236
N435MD
Miss March 2020
Old 04-15-2018, 03:55 PM
czechsix's Avatar
czechsix czechsix is offline
Originally Posted by control View Post
Hope it stays this good when the hinges are in place
Looks nice, did you have to do a lot of work to get that fit, or were the trim lines pretty close to perfect? One thing to keep in mind is that a small gap is a good thing to avoid chipping the paint when installing and removing the cowl...
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 04-15-2018, 04:36 PM
MED MED is offline
Thumbs up
Really looks like an airplane now!
MED
140236
N435MD
Miss March 2020
Old 05-03-2018, 02:37 AM
Currently nearly completed with the tail cone. Started Nov 1st of 2017. I am expecting my wing kit to arrive in about a week or two!!!
Scott Emerson
RV-14a Kit# 140432
