Old 01-12-2018, 05:44 PM
az_gila's Avatar
az_gila az_gila is offline
Question Baggage door alarm
Presently in the UK and contemplating wiring additions for my RV-10 project when I return.
The factory has door alarms for checking the main door pins are secure and these will need lights or similar panel warning devices, so why not add a third warning light for the baggage door?
The trouble is that I could not find a good spot for a microswitch location with a completed fuselage frame.
Has anyone come up with a neat solution?
PS The wiring bundles through the cabin area were getting bigger every day.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-12-2018, 06:32 PM
leok leok is offline
Gil,
I put a micro switch in the upper rear corner. It seemed like the best location to not be seen or snagged on something going in or out of the door. I made the bracket loop around the switch to provide protection. The bracket can be lightly bent to position the switch accurately.
See the pic below for details
[IMG][/IMG]
Building started Oct 5th 2014, Flying since 1/16/2020
http://www.mykitlog.com/leok
RV Hotel, come by and visit if you're in town
Dues paid 2020
Old 01-12-2018, 06:48 PM
Paul from Flyleds's Avatar
Paul from Flyleds Paul from Flyleds is offline
Hi Gil
We put a microswitch inside the channel that supports the rear seat backs, which just intrudes into the space of the top left corner of the door opening. Nicely tucked away in there!
Paul McVitty
Flyleds.com
VAF advertiser
Old 01-12-2018, 07:11 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Gil, my $0.02----forgetaboutit.
Not putting in a warning light = less cost, less weight, less time.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-12-2018, 07:19 PM
az_gila's Avatar
Smile
I thought about that too, but if you are wiring in two for the doors adding one more is probably simpler without a magnetic reed switch involved.
The first reply looks doable but I was hoping for details on a more hidden solution.
Gil Alexander
Old 01-12-2018, 07:21 PM
az_gila's Avatar
Post
Originally Posted by Paul from Flyleds View Post
Hi Gil
I'll look at that when I get back, but that structure was already completed by the previous owner of my QB kit.
Gil Alexander
Old 01-12-2018, 11:16 PM
awmuhs's Avatar
awmuhs awmuhs is offline
Default baggage door switch
I installed mine so that when the tab that holds the door closed engages it operates a micro switch. Door closed and latched.
Alan Muhs
Tucson, Arizona
Dues overpaid July 2020
RV12iS Southern Arizona Teen Aviation: #1 airplane sold, #2 airplane moved to airport/completing commissioning #3 airplane tail kit finished, wing kit received/fuselage ordered, #4 airplane tail kit finished
RV10 flying since July 2014- 750hrs as of April 2021
RV6A sold after 500 hours of flying
Old 01-13-2018, 02:24 AM
az_gila's Avatar
Thumbs up
That sounds like a great solution.
If it's OK with you I'll fly down and see it, and your Aerosport interior, when I return to Tucson.
Gil Alexander
Old 01-14-2018, 05:38 AM
awmuhs's Avatar
Default door alarm
Let me know when you want to come down
Alan Muhs
Tucson, Arizona
Old 01-14-2018, 07:12 AM
Lan Vinh Do's Avatar
Lan Vinh Do Lan Vinh Do is offline
Default door switch
I am not the builder of my rv-10 but mine have a switch that is wire with the left main door. So the left door and the bagage door have to be close to turn off my light.
Lan Vinh Do
RV-7A c-GOSV sold
RV-10 C-GMCE
Rv-7 emp completed but waiting boys to be older to help
donation 2020 done ( little bit earlyer)
