Old 11-05-2015, 10:32 AM
wirejock's Avatar
wirejock wirejock is online now
Default Thanks
Originally Posted by AviatorJ View Post
That is the process I used, except instead of a week, let the proseal and 3M tape sit for 3 days. I got my rudder down to take a look at that edge, it looks the same as my elevator and almost seems like instead of 3-3.5 rivets I should use longer ones... but per the Vans construction manual it states don't be tempted to do that.
I'll leave it for now until a Tech Counselor can take a look. Maybe the 10's just don't flatten out like on the 7. And I agree your work is fantastic.
I just checked out your blog. Parts like very nice. Blog is easy to navigate too.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 11-05-2015, 03:20 PM
AviatorJ AviatorJ is offline
Thanks I appreciate that. They're far from perfect but my hope is structurally everything is on point, the rest can get covered up with paint.
Justin
RV-10, N10JW
Flying since 2/14/2019
http://operationrv10.blogspot.com/
Old 04-16-2016, 09:34 AM
AdamB AdamB is offline
On my practice piece, I used the back rivet and mushroom set method.
Thinking I might use my pneumatic squeezer to partially set the rivets and finish with the mushroom set (possibly a flush die in a C-frame rivet set)
Maybe this will become more obvious as I do it, but with partially setting the rivets in alternating directions, doesn't that leave small bumps every other hole that interferes with keeping the back rivet plate flush to the skin on the rivet I'm trying to fully set??
RV10 - #41687
http://adamsrv10.wordpress.com
N56AB Reserved
Old 04-16-2016, 09:59 AM
wirejock's Avatar
Default Double flush
If you have rivets all inserted fom the same side, no. The factory side would be on the back rivet plate. Skipping around insures against pulling a curve in the trailing edge.
Now if you want every other rivet to be inserted from the opposite side, things may get interesting. I know some builders do it.
Larry Larson
Estes Park, CO
Disclaimer
Old 04-16-2016, 04:04 PM
Thanks, Larry.
I've seen others mention inserting rivets from opposite sides and guess I just figured I would do that as well as jumping around like described in the plans. In the end, the alternating sides didn't seem to make sense, as you say, might make things interesting. I think they turned out pretty good.
RV10 - #41687
N56AB Reserved
Old 04-16-2016, 05:04 PM
wirejock's Avatar
Default Rivets
Looks good to me!
Larry Larson
Estes Park, CO
Disclaimer
Old 11-13-2017, 03:29 PM
Mnemonics's Avatar
Mnemonics Mnemonics is offline
Default Mushroom head for Trailing Edge
Why do you use the mushroom head to finish the trailing edge?
Can't you use the back-rivet set to finish it?
I found that the back-rivet set can dent if you don't "end" perpendicular to the skin.
However I'm not able to use the mushroom head without either pounding the back-rivet plate or keeping it too much on the trailing edge pounding the skin (and stiffeners).
Which one should I "pound"?
Marcel Heijmans
RV-7 PH-MNX (reserved)
Blog ph-mnx.nl
Vlog YouTube: PH-MNX
Builder# 74668
Member NVAV
Old 11-13-2017, 08:39 PM
RandyAB RandyAB is offline
Hey Justin.
I too really like your blog. I agree with Larry that it is nice to navigate through and I've found it very helpful thinking through some of the build decisions that you've already made and articulated.
One point I have is with respect to alternating the shop and manufactured heads. It makes sense to me to do that on the rudder where both heads are equally visible but i don't think it makes sense on the elevator where it would seem to make more sense to put the manufactured head up for cosmetic reasons. That's what I did. I know that the main point of the post was how to set the rivets but I thought I would mention it.
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
Old 11-13-2017, 09:39 PM
wirejock's Avatar
Default Pounding
Marcel, I don't see a response to your question so I'll give it a try. If you can position the trailing edge at the edge of the back rivet plate, you should be able to "pound" the rivets without pounding the plate. Just make sure to check the position of parts every time. Nothing ruins a day like missing the plate.
Larry Larson
Estes Park, CO
Disclaimer
Old 11-14-2017, 08:33 PM
vernon smith's Avatar
vernon smith vernon smith is offline
My instructions said straight trailing edges was one of the most difficult parts of building a flying surface. With that in mind, and being far from accomplished with the rivet gun, I decided to find a way to get good reliable results with a dead straight trailing edge. I'm accustomed to building race cars in jigs and fixtures so Van's "in the air" method is all new to me, and a little scary. Point is, I'm blessed with tools and equipment most of you do not have and do not want to buy. One of them is a six foot by six-foot by .625 steel blanchard ground surface plate flat and square to .010. With this one can usually get a true result.
I milled an eleven-degree angle in a 4" x 2" x .5" steel block. This matches the angle of Van's trailing edge internal aluminum strip. The idea here is to end up with two parallel surfaces to squeeze against. Also, the oversized block insures everything stay flat and true without any dents or smiles in the skin.
I invested in the Numatx air over hydraulic squeezer because its half the weight of the pure pneumatic squeezers and comes with a foot pedal which is amazingly handy when you are trying to keep a couple of components aligned as is the case with the trailing edge rivet squeezing process.
Here is a picture of the simple steel block with the eleven-degree angle.
Above is the block positioned on the bottom of the trailing edge offering two dead parallel surfaces for the squeezer to work on. I installed the largest diameter flat squeezer set I had in the nonmoving side of the squeezer, and held it firmly over the shop head, then brought to piston up against the steel eleven-degree wedge block, and when all was well aligned squeezed the rivet. I had the entire structure clamped down on the surface plate so I could maintain a dead straight trailing edge with no problem.
I realize all this is worthless without the tooling but if you have a squeezer your local machine shop can make you the angle block or I'll send you mine, my next RV build is well over a year away
Last edited by vernon smith : 11-14-2017 at 08:34 PM. Reason: forum does not like Word line spacing
