  #11
Old 09-11-2017, 06:15 AM
Jasonm Jasonm is offline
I converted a snowblower into a tug for my 10. Works really well for one person and can covert it back in 30 minutes or so.
https://photos.app.goo.gl/SLOtgUacLnXDSE7v1
Jason McKay
RV-10
Old 09-11-2017, 08:04 AM
Michael Wellenzohn's Avatar
Michael Wellenzohn Michael Wellenzohn is offline
What'a wrong with pushing on the prop near the prop hub? Never heard that's an issue. Pushing or pulling uphill is always a pita.
Mike
RV-10 builder (flying)
#40511
Switzerland
Osh?18 OWW volunteer
Countries HB-YNN has visited:
🇨🇭 Switzerland, 🇩🇪 Germany, 🇦🇹 Austria, 🇮🇹 Italy, 🇭🇷 Croatia, 🇫🇷 France, 🇪🇸 Spain, 🇵🇹 Portugal, 🇸🇮 Slovenia, 🇭🇺 Hungary, 🇷🇴 Romania, 🇷🇸 Serbia, 🇨🇿 Czech Republic
www.wellenzohn.net
First flight Video: https://youtu.be/X7EQ81C3xSA
Old 09-11-2017, 08:38 AM
flion's Avatar
flion flion is offline
Go to Bogert Aviation and get the RVA Tow Pin Kit along with one of their tow bars. Now you can push your 10 without worrying about the bar slipping. I have been using this on my -6A ever since I damaged the nose wheel pant. Of course, the 2-place RV is not too bad to push around by hand, but I'm planning on getting a cheap little ATV to use as a tug for the -10, though while it's under construction I've had no problem moving it around as necessary.
EAA Technical Counselor #5357
Old 09-11-2017, 08:47 AM
Snowflake's Avatar
Snowflake Snowflake is online now
It doesn't make sense to prohibit this from a Physics standpoint either. The prop pulls the airplane in flight, and the airplane pushes on it when descending. A human pushing on it right at the root of the blade near the hub should not be able to cause damage.
As someone else pointed out, the "tow" bar is poorly named. It shouldn't be relied upon for anything other than steering. I've seen the damage that results when an old, worn one pops out unexpectedly while someone is pushing an airplane with it. You don't want that.
Rob Prior
Old 09-11-2017, 12:37 PM
Not cheap, but have a look here:
https://www.acairtechnology.com/products.aspx?cat=tugs
I want to get one of these for my non-RV.
Dave
Old 09-11-2017, 01:14 PM
civengpe civengpe is offline
Originally Posted by JackinMichigan View Post
...We have an MT composite prop, so no pushing on that. ....
I have an 3 blade MT and have always pushed the plane back with the prop. Is this something I'm not supposed to do?!?! My usual routine is to use the tow bar to steer and push on the prop at the hub.
Shannon
RV-10
Flying September 2015
Old 09-11-2017, 01:35 PM
DHeal DHeal is offline
If you use a "hangar floor mounted winch", be sure to have a secondary way to quickly depower the winch. Nothing gets the heart racing like releasing the winch's primary remote control switch and having the winch continue to pull the aircraft unabated into the hangar structure. On our Bonanza's hangar winch we could physically jerk the remote control cord to pull the winch's electrical power cord from its power outlet. Also, I question whether RV tail tiedown rings are suitable for pulling by a tail winch.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,080+ hours (as of Oct 2021)!
VAF donation through June 2022.
Old 09-11-2017, 02:01 PM
Sam Buchanan's Avatar
been here awhile
I'm intrigued by the idea of modifying a snow blower to get my RV-6 back into the hangar (seems that old plane gets a little heavier each year.....). But this will require the primary use of the blower to be in reverse gear.
Question: how fast is reverse gear on your snow blower? Just wondering if reverse is geared to allow satisfactory pulling of a tail dragger RV.
Sam Buchanan
RV-6
Old 09-11-2017, 04:05 PM
The reverse gear on mine runs about the same as first gear forward. I have five forward gears on mine and run in third most of the time.
Jason McKay
RV-10
Old 09-11-2017, 05:55 PM
been here awhile
Thanks for the feedback, Jason, that is useful info.
Sam Buchanan
RV-6
