Richard RG
Active Member
I'd like to install the Flyled combo lights in the leading edges of my RV3b using the Duckworks 4" par 36 install kit.
Does anyone have experience with this install? My understanding is the RV3 has a thinner wing profile than other Vans aircraft, so want to be certain I'm not ordering parts and pieces that won't fit. Possibly the RV4 has the same wing profile as the RV3? if so, does anyone have experience with the combo light install in the RV4?
Novice pilots with marginal English skills struggling with position reports and two bird strikes on visiting aircraft suggest installing wig wag lights may be a good idea.
Thanks for any suggestions for the install, or best options to make the little RV3 more visible.
