Thanks! I should have mentioned I'm indeed building a tip-up. I got the angle to follow the contour fairly well, but it's a little flat in spots at the most extreme curve, and I just wasn't sure if that really mattered enough to try again. Sounds like for the tip-up it shouldn't be a problem.
