Just pulled both mags off my -IO-540. Do you need the gears off the mage or the ones under the accessory case? I’m going w SDS eventually.
Edit: just looked part numbers. These are the drive gears. I’ve got both of them. Engine is stored 0 time since IRAN, 400 since major overhaul. PM if interested.
I need the gears that are resting in the accessory case. I just sent you a PM because I am removing a brand new SDS from an IO-540.
