... or gas that's $3.999 instead of $4.000.
On the speed units thing, I'll propose what I propose every time this subject cycles through the forums: furlongs per fortnight (eighths of a mile per two weeks). The conversion is 2688 fpf/mph, or 2337 fpf/knot. Marketing could have a field day with a 540,000 fpf airplane!
Let's not forget to use slugs as a measure of mass, too.
Virtually every system we use has some arbitrary basis. The only that *isn't* arbitrary, but has some actual mathematical soundness to it, is radians.
Hours? Arbitrarily dividing the day into 24 of them, because of who knows why. Minutes and seconds? Arbitrary.
Statute miles? Arbitrary, AND not "American" in the first place, but rather defined by the British formally in the 1500s. And based on yards, which are again, arbitrary. I always laugh when someone says we use miles because it's "American".
Meters come the closest to being not entirely arbitrary, since 1m is equal to 1/10,000,000th of the distance from the pole to the equator at sea level (which is not level at all, thus introducing the concepts of the geoid, etc.).
And nautical miles? Well, maybe in olden days the legend of using a rope to measure "knots" was true (or not, no pun intended), but the actual measurement today is 1 nm = 1' arc of longitude at the equator, or 1' of arc of latitude.
Want some more arbitrary units? We've talked about these...pounds (force) per square inch. Rotations per minute. Degrees Fahrenheit (talk about a dumb system...make the scale *first*, then figure out where your reference points, the freezing and boiling points of water, are on the scale, thus giving you two completely oddball numbers). Degrees (of arc)...360 of them in a circle? Who came up with *that*, instead of using radians? Gallons (at least a liter is equal to 1,000 cubic centimeters of water, which, ta da, is the equal to 1 kilogram).
ETA: I nearly forgot my favorite (stupid) unit...inches of mercury as a measurement of pressure. LOL!
The list goes on...
ATC uses knots. That's why I use it.
Manufacturers use mph because a) it sounds faster, and b) in the 60s and 70s, they were trying to appeal to the automobile-buying public, by making planes "as easy as a car". In other words, marketing.
