Dallas Avionics has made an agreement with uAvionix to supply a replacement ADS-B for customers who suffered from the AD on Navworx products. Discounts are available when a customer provides the serial number of their experimental unit. This is not for certified customers. YET.
I will paste the press release below. As before, Scott Edwards will be the primary POC. I have personally followed uAvionix in the UAV market for several years. They have mature products and engineering. Replacing the experimental Navworx should be straight forward with the available plug and play harnesses. It is unfortunate that Dallas Avionics got caught up in a product no longer available. Losses financially are large. This solution is at least a step towards making individual customers ready for the ADS-B mandate. Cheers, Nick
ALLAS, TEXAS DATE) Dallas Avionics, Inc. announced today that the company is working with uAvionix to offer an affordable ADS-B solution for customers of experimental aircraft impacted by the ADS600-B. The uAvionix bundle includes the uAvionix echoUAT and skyFYX products. For a limited time, Dallas Avionics will offer the bundle at a reduced price of $1,090.00. Normal retail is $1,499.00. The bundle can be ordered using part number ECHOFYX-KL5. Customers must provide the serial number of their ADS600-B to obtain the reduced price.
?There are a lot of people in the aviation industry that fly experimental aircraft that were negatively impacted by the ADS600-B,? said Dallas Avionics Vice President of Sales Scott Davis. ?We were thankful to partner with uAvionix to provide a solution quickly to help those that need a replacement. For decades Dallas Avionics has built a reputation of taking care of customers. We wanted to find an ADS-B solution that was affordable, easy to install and helped all those impacted receive a proven solution at a discounted rate to help them become compliant. The solution from uAvionix gives our customers the equipment necessary to accomplish that.?
The plug and play connector will make the bundle easy for experimental aircraft operators to replace the existing system. Using the plug and play harness, customers can quickly install the two products in their aircraft after removing the ADS600-B. Both the echoUAT and skyFYX are lightweight and small so they will not require a lot of space.
