I need to trim the inboard edges of the wing skins to get the right gap for the seals. What tool works best? It's really slow going with a flat file.
My favorite tool for this is a Dremel with reinforced cut-off discs....BUT, make sure you practice on scrap first. It takes a little learning curve to do straight lines. Do NOT use non-reinforced discs. They will not take side loads and are very dangerous when they come apart.I need to trim the inboard edges of the wing skins to get the right gap for the seals. What tool works best? It's really slow going with a flat file.
Any recommendations for a battery operated one? Any experience with the Milwaukee ones?Belt sander, or sanding block, depending on how much to remove.
