DeltaRomeo
doug reeves: unfluencer
Staff member
Pushed out a little early - side hustle busting up the calendar for a bit. Hope you had a really nice weekend. V/r,dr
dr
RV6-KPTW RV-10
Clambake Update
RE Throttle / Mixture Bracket Suggestions
….terrye
I'm just finished this part of my build, IO-320 Superior cold air sump, Precision servo. I did not use the Vans throttle brackets, instead made my own. I got the dimensions for the bosses on the sump from Aerosport Power, they are at weird angles so be careful. I used the Vans mixture belcrank and hardware and cable bracket, but because of the boss at the front of the sump, I decided to make my own belcrank bracket. The Vans engine cables seem to work, although my mixture cable does not go through the Vans location so it is a little tight but still workable.
scorwin
RE Rudder Trim
…Foghorn
I also copied another builder’s idea. I had a machine shop make mine. I’ll see if I can find my plans for this.
RE Home Brewed O2 System
…Majorpayne317641
I did this on my RV-8A and I love it. The OP is using a Bluetooth sensor I did the same. I would never go back! In the summer time flying at 17k and 36F outside is perfection! I was going to write up a post on my permanent/removable configuration but haven’t had the time. The idea is the bulk head connections allow for you to completely remove tank, lines and bracket to allow for full use of baggage area. I can do one if there is interest. Here are the pics.
Future considerations are to add a cockpit selectable blow off valve to vent over board in case of forced landing.
RE Ballast
…gasman
SuperCubDriver Back Home
Back home again !
Departed Wick at 08:45 LT in the morning, ceiling 700 ft. For the next hour flew between 700´ and 3000´. It cleared up near Newcastle where I climbed to FL 095 and picked up TAS. From there the weather was good all the way to Mannheim in Germany where I cleared customs into the EU. Then followed the last short leg of the tour to homebase where I was greeted by friends and clubmembers. Two pilot friends followed me the last miles with their Extra 300 for a low pass before landing. As usual my wife "Miss Shan" and friends prepared snacks, coffee and drinks for the welcome home.
Lycosaurus
Mechmike
TASEsq
….engine painting update
OFF TOPIC:
