DeltaRomeo
doug reeves: unfluencer
Staff member
Felt mighty good. Fog west of the field - I needed to keep an eye on that, so only time for three TnGs to get ‘RV current’ so to speak. Rolled over the field about 30 min after landing.
Man, it felt good to get back in the RV-6. Those descending base to finals* with the fog off in the distance, no bumps and low sun angle surely did reset my mental gyros.
If you look close you’ll see another RV-6 at the runup ramp that had the same idea.
A good day.
v/r,dr
*The first two TnGs down to about a foot and then power up to save tire tread and practice manual flaps 2 to 1 without overspeeding ‘um. Great fun!
In the "booth", I used a spray table having 1/2" hardware cloth surface, and a filtered box fan exhaust below the table. I used the Stewart Eco_Prime water-based primer, so the drying time was practically zero and I could do it in the house in the winter. The 1/2" mesh was a good size to keep the small parts, too. Stringing up all the parts on frames would be very time consuming, if you're priming everything as I did (I know, I know....).
Lycoming Crankshaft Forging Shortage
OFF TOPIC:
Past ‘VAF News’ issues:
