Actually, 24/27 is closer to .89 (RPM ratio), and 0.89 cubed is about .70... 70%(Power ratio). Your equation is valid too. It's just that torque required to turn a propeller goes up with the square of the RPM, so torque x RPM is proportional to RPM^2 x RPM, or RPM^3.
This I'll buy. :D
And if I had read your first post more carefully, I might have intuited that meaning (and saved us both a bunch of time). But when you lead off with
Power is a cube function of RPM.
the implication is that you are describing engine hp, not engine hp minus prop drag.
I suppose "net horsepower delivered" is just too verbose... :)
Some you aero or mechanical engineers correct me if I'm wrong, but I believe the correct term for torque x RPM/5252 is "brake" or "shaft" horespower. On an airplane it is basically horsepower input to the prop, but that formula works for any engine or motor, whether it's turning a propeller or wheels, or whether the energy source is petroleum, electricity, steam, or whatever.
The power left over after you deduct for the the inefficiencies of the propeller is "thrust" horsepower, which is the power output from the propeller that goes into overcoming the total drag of the airplane at a particular speed. In many texts, I see the number 80% assumed for propeller efficiency for most calculations. That is, for every 100 brake or shaft HP input to the average propeller, you get 80 thrust HP out of it.
Yah, torque curve is pretty flat over the normal RPM range in a lyc. So, using a constant torque for T*RPM/5252 puts you in the ballpark pretty close. Close enough for the planes I date.
I think the challenge here (in the off topic portion of this thread...) is that there is an assumption that the torque will match the "dyno" torque. I.e., full throttle, and use whatever torque it takes to limit the engine's rpm to various points, generating a curve. Those curves are max torque an engine can make for a given rpm. This won't be the case with a fixed pitch prop. The torque will not be constant, but will be something close to the cubic function of rpm discussed by several of us. Lots of other variables also...airspeed, etc.
Fixed Pitch systems behavior
One more off topic post... :D
Perhaps why I was fixated on engine behavior instead of systems behavior at the start of this sub-thread is that the beginning of the main thread was about climb out, i.e. full throttle - full MP performance.
It should be reasonably accurate that the engine will be putting out hp relative to the cube of rpm when in level cruise flight, or static run-up. This is the intrinsic behavior of the prop.
But during climb-out (assuming full throttle), the engine will perform like an engine on a dyno. Again, this assumes rpm is being controlled by aircraft pitch angle. 2400rpm, for example, would be putting out 89% power. The pitch angle is a substitute for the blue knob.
And of course when one points the nose down things get confusing in a whole different way. You could get 2400rpm with the red knob pulled all the way out. :)
But if the goal is 70% power, 2400rpm is only going to deliver that at sea level cruise, and that assumes that full throttle cruise gives you 2700rpm.
C'mon Bob, jump back in and give us something else to chew on - I'm drowning in cubic functions of RPM and horsepower! :eek:
I had another problem last night and she's back in the barn doing a paperweight impersonation. I put details on the blog but decided not to post here because... err.... just because.
Hi Bob, Just trying to help a little here. I don't know what spark plugs you are running but if they are Champions you might want to check them. If purchased recently and fine wires you might want to really check them. Check for resistance and cracked insulators. They have been having QC issues lately. On the throttle cable issue, take it off at the fuel servo and see if it is still stiff. Take care,
I don't know what spark plugs you are running but if they are Champions you might want to check them. They have been having QC issues lately.
They have been having quality control issues for about the last 15 years. Been there, done that :cool:
I only know what I have experienced. There have been articles of late by Mike Busch on fine wires. My massive plugs have had issues. But only in the last year.
I can imagine how nice it is to have figured out what the issue was with the engine. On a car, it is one thing, but on a plane, it is still one thing, but you are in the air!
Have fun putting on those hours to break in the engine.
Great news Bob - it is always good when you can actually positively identify a cause, and then see the results of better performance once it is fixed.
Lessons learned?
Congratulations on getting things sorted out.
But I wonder...
As I've read about the issues you've discussed here over the past couple of months, it seems like there must be some lessons here that might be useful for those of us who are not yet finished, or even nearly finished.
I seem to remember a thread discussing concerns about ground testing an engine, and another about how to diagnose engine performance issues prior to first flight.
I wonder if perhaps in hindsight that the issues with your engine could have been caught prior to first fight (or 3rd or 4th flight). If so, how?
I hope this question doesn't sound like a criticism at all. It's not intended to be. I just know that I have very little experience, and hope to learn from the experience of others.
Search the forums. I started threads about chasing the suspicion of a static RPM two months ago. But here's the thing: They didn't start out as chasing engine performance problems. They started as a thread about the FAA's requirement for an hour of ground run time.
Read these for more extensive information on the search:
The paperwork challenge
Diagnosing engine performance
Installing mags
It started with what appeared to be a low static RPM, but there was some disagreement over what a proper static RPM should be given a prop combination, not to mention the inadvisability of excessive ground runs beyond 2000.
Eventually, we figured out that the problem was a mistimed mag, which might have been another forum thread actually, but it was extensively documented, including on that fine little RV building blog.
I would say the issue(s) of the engine has been going on -- and been documented -- in one fashion or another for about two months. Are they all related? We don't know now, we certainly had no way of knowing then. Was the blocked fuel injector the problem two months ago? I have no way of knowing that. Neither does anyone else
So the lesson is: You search for your problems one at a time and solve them to your satisfaction one at a time. Maybe another one crops up, maybe it doesn't. Maybe the problem of one hides within the problem of another.
The lesson is: You don't know. And you better be ready.
When all is said and done, you test and fix, test and fix. I've been doing that for months on this particular issue which may have several different causes disguised as one.
But, really, that starts the minute you put the engine on the engine mount. You're always looking for things that might go wrong...which is why I spent months on fuel flow testing, clamping of wires, securing of SCAT, chafing issues, oil leaks, pulling out
fuel and oil lines and having them made better.
And then there's this little baby. I found this while looking for problems that hadn't presented themselves yet. Imagine if I'd actually gone flying with this garbage.
I think people have to go into Phase I with eyes wide open on this point and understand that you're going to find things that go wrong, and then you diagnose and fix them as they occur, then test to see the effect of the fix. Make sure your flying is up to snuff. Make sure you didn't just take enough transition training to satisfy your insurance company. Make sure you're a **** of a test pilot.
Also, if you're lucky like me, you've met the best and brightest on Planet RV in the course of building, and when you think you might have a problem, they drop what they're doing and come to your hangar, giving up time with their families to help you out, or they call you from halfway across the country to lend a supportive ear and some advice, and never once -- not once -- make you feel stupid.
So the big lesson: Get yourself friends like that.
How wise and there is a big payoff
You have certainly done well and reported the events as they occurred with no sugar coating. I swear there is a common attitude that this Phase 1 testing is just a burden imposed on us builders with no rational justification. You and I know from our experience as first time builders that it is a risky time with MANY opportunities for failure. And, I know you know you are not out of the woods yet. Just to reinforce what you are already learning I'm sure is, these really are pretty good little airplanes. Thursday I climbed in our little RV-6A and flew by myself from Fayetteville, Arkansas at 6:40 am CDT to Ephrata, Washington, against the prevailing winds with fuel stops in Goodland, Kansas, Sheridan, Wyoming and Missoula, Montana and arrived at my destination at 7 pm CDT (5 pm PDT) that same evening. The airplane wasn't even breathing hard. I flew it at max power over a 170 mile course on Saturday averaging over 216 mph then headed home with an overnight stop in Sheridan only because I have no lights in race configuration. These are REAL AIRPLANES by any standard of reliability or performance with all of the building demands and integration and test requirements of any high quality, high performance airplane without the frail nature of some others. However, the "years in process" systems in the end do have to be integrated and tested for both function and performance and the faults detected and fixed.
Bob Axsom
(Cross posted from the blog)
Flight Test Follies: The drug test
It was pee-in-a-cup night for N614EF as the flight test period continues.
Although the plane performed much better once we removed crud from the #1 cylinder injector on Sunday, the exhaust gas temperature and the cylinder head temperature for the cylinder were higher than for other cylinders, indicating that perhaps the mixture was a little leaner in that cylinder than it should be.
So today I took the injection line off again and checked the injector again and, sure enough, there was a speck of dirt blocking things a bit; it wasn't as bad as what we pulled out of there on Sunday, but it was clearly enough to deprive the cylinder of all the fuel it needs to run efficiently and stay relatively cool.
You can see the small speck -- which looked like a flake of primer -- at the end of the safety wire I used to poke it out. You might have to click on the image to see it.
After that, I wanted to check all four lines to see if they were putting out a fairly equal amount of fuel. So I stuck some Dixie cups at each injector and flushed out the lines, dumped the fuel and then turned on the boost pump for 15 seconds.
Then I weighed each cup and found that each was within 1 gram or so. The last cup I weighed, the #4 cylinder, showed only 16 grams but I'm chocking this up to them being paper cups and some of the fuel leaking out of them in the time it took me to weigh the other three. Whatever, the #4 cylinder hasn't been much of a bother up to now.
So all that was left was to start the engine for a light look at things. It's too windy to do any flying. In about a 7 minute exercise, all four cylinder temperatures were within 4 or 5 degrees of each other -- that's a big difference from the last few months when #1 was noticeably hotter. And the number 1 exhaust gas temperatures were quite a bit below the other three. That's not much of a change.
We'll see if a flight later this week reveals any difference in temperatures but the engine is sounding better and better -- smoother -- to me than it has in quite awhile.
Wow Bob, I feel like a proud papa....you're all grown up and pulling/cleaning injectors like you've been at it your whole life! Isn't this test period thing fun? Look at all the new skills you're acquiring! In all seriousness, well done and keep up the good work.
Stein
Stein
Taking stuff off, putting it back on. Taking it off. Putting it on. It's way more fun than building and writing checks all the time.
If the injector keeps clogging, you might want to check your filter! Might be more upstream.
