RV6-KPTW
Friend
As I am assembling the individual parts, I note that not all result in a tight connection. There is a fair bit of slop at the F-1065 pushrod into WD-1011 intersection. Note the gap between the Vans supplied steel washers and the rod end bearing at the top inside of the control stick base. Add washers, Squeeze WD-1011, chill out?
