Hey guys,
Just received RV Practice Kit-1 (the faux control surface), and am now beginning tool acquisition so I can actually build the practice project. I think I'm going to go mostly with Isham stuff.
Nugget
you know, i'm just measuring the thickness of the spar... .040 and looking at the section 5e in the manual that isn't enough to get a good machine countersink. on the practice kit it does say specifically to use the machine countersink??
so yes, the reason is probably that material is too thin to countersink as the bit gets lower, the hole enlarges!
thanks for the info on it. and yes the 3 drops in too low now but before the skin would sit too high around the countersink holes and not flush with the spar.
Look at these new cleco pliers! Both rubberized handles are still thereAdam you better glue the lower one.
Unfortunately rubber hadn't been invented when I bought my cleco pliers.
Sure you can. You just have to be careful to bring the squeezer down slowly with the cupped set held in place before the final squeeze. Everything takes practice. You'll get there.-You can't place the cupped set on the moving part of a pneumatic squeezer.
