Kicking back is what I will do. The product I would use is Muggy formulation #1. This uses a flux that is non corrosive and allows the product to flow. There are other products that may work as well. But there are many questions before this can really be considered. What are the consequences of heating 2024 locally to 350 degrees? Will this procedure truly seal the rivet? How will it work over time with temperature changes, vibration, etc? Is the filler and flux truly non corrosive over time? A test tank built to test this idea would be easy enough. And if it did work it may be a very good way to do tanks in the future.
