It's true that Pmax needs to be about 12°-15° for maximum brake torque (MBT) so on a fixed ignition system engine, there will be an engine speed where this will be so. Unfortunately, it will depend on air-fuel ratio, altitude (trapped residual exhaust gas) and load.
The burn rate (flame front speed and other stuff) does have an effect on efficiency as a slow relative burn rate 'rounds off' the peak in a p-V indicator diagram. Theory assumes infinite burn rate (which would be incredibly noisy!) but slowing the engine down brings reality closer to theory, since the combustion occurs over a smaller crank angle sector.
(p-V Diagram - theoretical)
(p-V Diagram - real life-ish - note rounded corners which reduce the area of the curve. Clockwise area represents work output. Anticlockwise area represents losses as in the gas-exchange loop at the bottom)
Two other things are happening that are engine speed dependant. First is engine friction - there is a n² function happening here, where going slower decreases friction. Secondly, heat transfer from the combustion chamber to the environment is a function of time, so in this case, speeding up reduces heat losses.
These three factors (and others) drive a minima somewhere between 0rpm and 2700rpm. The test engineer's job is to fly some measurements to find it!
So, in summary:
- Going slower increases effective burn rate (+)
- Going slower increases mechanical efficiency (+)
- Going slower increases thermal losses (-)
Also,
- Going leaner* lowers peak temperature and therefore thermal losses (+)
- Going leaner* increases ratio of specific heats (gamma) and increases thermal efficiency (+)
- Going leaner* slows burn rate therefore retards Pmax angle (-) go slower to compensate
Most importantly! Going slower with higher loads increases the risk of knock (a.k.a. detonation, pinking etc) Take care!
Also, If you get the chance to fiddle with the ignition angle, then LOP becomes meaningless and you need to target an air-fuel ratio as well as optimum ignition angle. Not necessarily more complicated - just a different and probably better optimum to find.
A
* leaner in the sense of LOP - i.e. real lean! Not leaner than full rich, which is starting on the other side of the hump, so it will get hotter for a bit before it gets cooler!
