texdog
Where can I find a 3 prong male plug for a ND14824 alternator? I’ve searched the local auto parts stores and they don’t seem to be able to get the pig tail. I only use one wire on the plug in.
Have you looked up what vehicles that alternator goes into, then tried finding the pigtail for those vehicles?
Once you try that, I'd look on rockauto.com
I didn't bother. Only the Field terminal needs a connection and a plastic insulated 1/4" fast on connector works well. The Stator connection is not needed and the ground can be taken off the case.
