anyone doing it for experimental (self install), also 635?
The typical current draw is the same for both the GTN 650 and GTN 650Xi Series Navigators.
Is that also true for the 750 vs 750xi?
I'm confused that this Garmin page says the Xi draws less current, but you're saying that's not true:
https://support.garmin.com/en-IN/?faq=KJyG9T0bzF6GMpPLnQUQZ9
So what are the typical and peak currents for the 750xi?
Are the connector kits and configuration module between the original GTNs and the new GTN xi versions exactly the same? I think the answer is "yes" but don't like surprises.
I have a GTN 750 new in the box but the connector kit (p/n 011-02326-02 ) has already been installed on a pre-made harness with the configuration module. I have a new GTN 750xi on the way to put in this same airplane the harness was made for but I am sending the original GTN 750 off to another airplane. My intent to is to send the connector kit in the box with the new GTN 750xi unit off with the original GTN 750 with the expectation that there is no difference between the connectors and config module.
I could answer this question if I had the installation manual for the new GTNxi series but I only have the manual for the legacy GTNs. So is the connector kit (p/n 011-02326-02) the same or effectively the same for the old/new units?
Thanks.
You would think that they would have built the flight stream into the unit.
